Home » Eclipse Projects » Eclipse Platform » Re: EMF Databinding using WritableValue
Re: EMF Databinding using WritableValue [message #334131] Wed, 21 January 2009 16:25 Go to next message
Thomas Schindl is currently offline Thomas SchindlFriend
Hi Jan,
Please ask such generic databinding questions at the eclipse.platform
newsgroup.
Tom
Jan Kohnert schrieb:
> Hello,
> I'm using EMF Databinding.
> IObservableValue modelOberservable =
> EMFEditObservables.observeDetailValue(Realm.getDefault(), editingDomain,
> writableValue, feature);
> When ever the selection changes I update the writableValue
> (org.eclipse.core.databinding.observable.value.WritableValue ).
> Now I want to change a list of objects when ever the selection contains
> more than one object of the specific type. For example, I have three
> Persons selected ant by typing something into a databounded textfield I
> want the change to be made to all three persons.
> How can this be done?
> Thanks!
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: EMF Databinding using WritableValue [message #334139 is a reply to message #334131] Thu, 22 January 2009 00:00 Go to previous messageGo to next message
Matthew Hall is currently offline Matthew HallFriend
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=175735
Matthew
>> Hello,
>> Thanks!
Re: EMF Databinding using WritableValue [message #334154 is a reply to message #334139] Thu, 22 January 2009 09:48 Go to previous messageGo to next message
Jan Kohnert is currently offline Jan KohnertFriend
Matthew,
If I understand it right, all I've to do is to update to Eclipse 3.5m5 and
use the API providet with it??
Jan
Re: EMF Databinding using WritableValue [message #334161 is a reply to message #334154] Thu, 22 January 2009 17:28 Go to previous message
> and use the API providet with it??
No, the API is not yet implemented. The link I gave you points to the
bug report where development on the feature is being tracked.
Matthew
Previous Topic:[JFace] Text and Dialog button CellEditor?
Next Topic:JFACE wizard next button implementation
Current Time: Thu Aug 29 20:53:19 GMT 2024
Powered by FUDForum. Page generated in 0.02610 seconds
