Home » Eclipse Projects » Eclipse Platform » Login and then load plugins based on permissions.
Login and then load plugins based on permissions. [message #334057] |
Fri, 16 January 2009 19:24 |
Originally posted by: kathir.atc.tcs.com
I am trying to create an RCP application wher the user will login and then
based on his role the application functionalities are loaded.
I would like to use the equinox security implementation to do the login but
i am not sure how to load the plugin functionalities based on his role.
Here are the two approaches i thought of.
First Approach :
1. Application plugin - Login ( want to use Equinox Security )
2. Retrieve the Role of the user
3. Set the activities ( Eclipse Activity ) based on the Role.
Second Approach :
1. Application plugin - Login ( Equinox Security )
2. Retrieve the Role of the user and write the XSLT Transform files.
I do not know whether the second approach is right or not because i could nt
really get the sample xslt transform from the eclipse cvs to work and didnt
get any response from the newsgroup either.
So if anyone could throw some light on this, that will really help me
understand the Equinox Secuirty and Transform.
Kathir.
Re: Login and then load plugins based on permissions. [message #334102 is a reply to message #334101] |
Tue, 20 January 2009 23:40 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
We are simply extending the expression framework and add declartive
checks to user privileges. You can look at an example application i've
created [1,2,3].
Tom
[1] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui/plugin.xml
[2] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui/src/at/bestsolution/socce r/ui/internal/LoginSourceProvider.java
[3] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui.associationadmin/plugin.x ml
Kathir schrieb:
> I have looked into the eclipse-jaas from the sourceforge. Its basically
> installing plugins if the user is a authorized user.
> But in my case, i have to disable commands and views based on the user
> permissions. And also i cannot create plugins for each view and command,
> that will get me 100s of plugins.
> I think, if i can get the xslt constructed based on the User Permissions ,
> the application will have the authroized extensions installed in the
> application.
> Please correct me if i am wrong on this.
> Kathir.
> "Paul Webster" <pwebster@ca.ibm.com> wrote in message
> news:gl573i$4ka$1@build.eclipse.org...
>> Kathir wrote:
>>> Hi Paul,
>>> <xsl:stylesheet version="1.0"
>>> xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
>>> <xsl:template
>>> match="actionSet[@id='com.seq.diagnostics.PlateActionSets]" >
>> ^^^ typo?
>>> I had the
>>> osgi.framework.extensions=org.eclipse.equinox.transforms.hoo k
>>> and the start level for the xslt and my application plugin with @1\:start
>>> But when i run the application i dont see the actionset visible.
>> Did you copy out all of the working code from
>> org.eclipse.equinox.transforms.xslt.plugin? That's the plugin that uses
>> org.eclipse.equinox.transforms.hook, org.eclipse.equinox.transforms.xslt
>> to do the transform.
>> PW
>> Paul Webster
>> http://wiki.eclipse.org/Platform_Command_Framework
>> http://wiki.eclipse.org/Command_Core_Expressions
>> http://wiki.eclipse.org/Menu_Contributions
>> http://wiki.eclipse.org/Menus_Extension_Mapping
>> http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/workbench.htm
Re: Login and then load plugins based on permissions. [message #334103 is a reply to message #334102] |
Wed, 21 January 2009 00:12 |
Hi Tom,
The LoginSourceProvider set the SOURCE_USER_GROUP to the user's group and
based on the this group type , the CommandHandler is enabled or disabled. -
Will it be possible to write a trojan plugin to make this commands enabled ,
i am just thinking whether it will be possible.
How do we do this for the views and perspectives?.
BR,
Kathir.
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:gl5ne1$e3g$1@build.eclipse.org...
> created [1,2,3].
> Tom
>> application.
>> Kathir.
>>> Kathir wrote:
>>>> Hi Paul,
>>>> <xsl:template
>>> ^^^ typo?
>>>> I had the
>>>> @1\:start
>>> PW
>>> Paul Webster
Re: Login and then load plugins based on permissions. [message #334138 is a reply to message #334102] |
Wed, 21 January 2009 23:15 |
Hi Tom,
I followed the expressions approach to enable/disable commands. But it does
not seem to work.
I used enabledWhen insteadof activeWhen but no matter what i set to the
variable it never gets enabled.
<enabledWhen>
<with
variable="com.sequenom.ivd.users.factory.ADD_USER">
<equals
value="true">
</equals>
</with>
</enabledWhen>
I returned the map with com.sequenom.ivd.users.factory.ADD_USER = true but
the command is not enabled. What am i doing wrong.
Kathir.
> created [1,2,3].
> Tom
>> application.
>> Kathir.
>>> Kathir wrote:
>>>> Hi Paul,
>>>> <xsl:template
>>> ^^^ typo?
>>>> I had the
>>>> @1\:start
>>> PW
>>> Paul Webster
Re: Login and then load plugins based on permissions. [message #334141 is a reply to message #334138] |
Thu, 22 January 2009 00:13 |
and if i use activeWhen it is always enabled.
<activeWhen>
<with
<equals
value="true">
</equals>
</with>
</activeWhen>
in the source provider
public static final String ADD_USER =
"com.sequenom.ivd.users.factory.ADD_USER";
public Map getCurrentState()
HashMap<String, Object> map = new HashMap<String, Object>();
map.put(ADD_USER, "false");
return map;
IT is enabled in this case even though i return false for the variable.
"Kathir" <kathir@atc.tcs.com> wrote in message
news:gl8abd$7a4$1@build.eclipse.org...
> Hi Tom,
> does not seem to work.
> <enabledWhen>
> <with
> <equals
> value="true">
> </equals>
> </with>
> </enabledWhen>
> Kathir.
>> created [1,2,3].
>> Tom
>>> application.
>>> Kathir.
>>>> Kathir wrote:
>>>>> Hi Paul,
>>>>> <xsl:template
>>>> ^^^ typo?
>>>>> I had the
>>>>> @1\:start
>>>> uses
>>>> PW
>>>> Paul Webster
Current Time: Wed Jul 17 15:39:14 GMT 2024
Powered by FUDForum. Page generated in 0.04734 seconds
