Home » Eclipse Projects » Eclipse Platform » Where to write initialization code before plug-in launches?
Where to write initialization code before plug-in launches? [message #334040] Fri, 16 January 2009 05:26 Go to next message
I am writing an eclipse plug-in.
Is there some init method / some other place where I can add some code
when eclipse launches and before start() method of my plug-in class gets
called?
Thanks.
Re: Where to write initialization code before plug-in launches? [message #334045 is a reply to message #334040] Fri, 16 January 2009 09:59 Go to previous message
kaprasi wrote:
> Hello,
> called?
> Thanks.
What are you seeking to do? What is wrong with using the start() method
of your plug-in or another plug-in of yours?
In Eclipse, there is the org.eclipse.ui.startup extension point that can
be used to initialize things when the workbench is brought up, but I
discourage people from using this. The problem is that people think they
have the most important plug-in in the world when in reality, they
should play nicely with everyone else.
~ Chris
Previous Topic:[Common Navigator] possible memory problems w/ NavigatorContentDescriptorManager
Next Topic:Help getting popup menu item to appear based on a System Property
Current Time: Fri Oct 24 05:50:12 EDT 2025
Powered by FUDForum. Page generated in 0.03905 seconds
