Home » Eclipse Projects » Eclipse Platform » How to force something into the UI thread
How to force something into the UI thread [message #333992] |
Thu, 15 January 2009 12:14 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: szchaler.acm.org
I am using DebugUITools.launch to trigger a certain launch configuration
programmatically. All is well, but sporadically I get a
NullPointerException from the DebugUITools.launchInBackground call.
Honestly, I have no idea how it would even get to the point of the
exception, because that should only ever be reached if there are any
build jobs around and I am trying to make very sure there aren't by
joining those before calling launch, but still...
In the javadoc for DebugUITools.launch I read that this method should be
called from the UI thread. So, currently I am working on the assumption
that hopefully my problems will be gone if I can ensure that the call is
executed in the UI thread. I've read in a different thread in this group
that there is no way to find out if I am in the UI Thread. But is there,
maybe, a way to force something into the UI thread? Can I, e.g.,
schedule a Job or Runnable to be executed within the UI thread?
Many thanks in advance for any pointers,
Steffen
Dr. rer. nat. Steffen Zschaler
Senior Research Associate
Lancaster University
Lancaster, United Kingdom
Email szschaler@acm.org
Phone +44 (01524) 510354
WWW http://www.steffen-zschaler.de/
Consider submitting to ECMDA-FA 2009, the 5th European Conference on
Model-Driven Architecture Foundations and Applications.
http://www.ecmda-fa.org/
Consider submitting to QoSA 2009, the 5th International Conference on
the Quality of Software-Architectures.
http://qosa.ipd.uka.de/
Consider submitting to MiSE 2009, the 3rd International Workshop on
Models in Software Engineering
http://wikiserver.sse.cs.tu-bs.de/mise09
Re: How to force something into the UI thread [message #333996 is a reply to message #333992] |
Thu, 15 January 2009 13:40 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Ed Merks![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ed.merks%40gmail.com) Messages: 33188 Registered: July 2009 |
Steffen,
Display.syncExec,which can deadlock, and Display.asyncExec are useful.
One way to get the display is with Disply.getDefault()...
Steffen Zschaler wrote:
> configuration programmatically. All is well, but sporadically I get a
> be called from the UI thread. So, currently I am working on the
> assumption that hopefully my problems will be gone if I can ensure
> that the call is executed in the UI thread. I've read in a different
> thread in this group that there is no way to find out if I am in the
> UI Thread. But is there, maybe, a way to force something into the UI
> thread? Can I, e.g., schedule a Job or Runnable to be executed within
> the UI thread?
> Steffen
Ed Merks
Re: How to force something into the UI thread [message #334003 is a reply to message #333996] |
Thu, 15 January 2009 15:25 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thanks, Ed, for the quick reply. It seems one can even use
Display.getCurrent() to find out if one is in a UI thread or not...
Steffen
Ed Merks wrote:
> Steffen,
> useful. One way to get the display is with Disply.getDefault()...
>> the UI thread?
>> Steffen
Re: How to force something into the UI thread [message #334066 is a reply to message #334003] |
Sat, 17 January 2009 20:06 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Nicolas Bihan![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=n.bihan%40itnsa.com) Messages: 49 Registered: July 2009 |
Member |
You should consider too :
PlatformUI.getWorkbench().getDisplay()
From Javadoc :
"Returns the display for this workbench.
Code should always ask the workbench for the display rather than rely on
Display.getDefault().
Returns:
the display to be used for all UI interactions with this workbench"
Nicolas Bihan
> Steffen
> Ed Merks wrote:
>> Steffen,
>>> Hi,
>>> the UI thread?
>>> Steffen
Re: How to force something into the UI thread [message #334072 is a reply to message #334066] |
Mon, 19 January 2009 09:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Many thanks for the pointer. I've adjusted my code accordingly.
Steffen
> From Javadoc :
> on Display.getDefault().
> Returns:
> Nicolas Bihan
>> Steffen
>> Ed Merks wrote:
>>> Steffen,
>>>> Hi,
>>>> a NullPointerException from the DebugUITools.launchInBackground
>>>> call. Honestly, I have no idea how it would even get to the point
>>>> of the exception, because that should only ever be reached if there
>>>> are any build jobs around and I am trying to make very sure there
>>>> aren't by joining those before calling launch, but still...
>>>> should be called from the UI thread. So, currently I am working on
>>>> the assumption that hopefully my problems will be gone if I can
>>>> ensure that the call is executed in the UI thread. I've read in a
>>>> different thread in this group that there is no way to find out if
>>>> I am in the UI Thread. But is there, maybe, a way to force
>>>> something into the UI thread? Can I, e.g., schedule a Job or
>>>> Steffen
Current Time: Sat Jul 27 12:36:44 GMT 2024
Powered by FUDForum. Page generated in 0.03360 seconds
