Undo does not work in 3.4? [message #333946] |
Wed, 14 January 2009 15:58 |
Originally posted by: paul.paulgalbraith.net
Basic undo functionality does not seem to work in the text editors in
eclipse 3.4, has anyone else noticed this problem? I'm assuming I'd
see/hear a lot more about this if everyone else was having the same
problem, but figured I'd ask just in case someone else out there has
this problem, too?
Re: Undo does not work in 3.4? [message #333954 is a reply to message #333946] |
Wed, 14 January 2009 16:38 |
Walter Harley Messages: 847 Registered: July 2009 |
"Paul Galbraith" <paul@paulgalbraith.net> wrote in message
news:gkl233$daq$1@build.eclipse.org...
> problem, but figured I'd ask just in case someone else out there has this
> problem, too?
I think your assumption is correct, although one way to check is to search
for bug reports in Bugzilla. (FWIW, undo seems to be working fine for me;
I'd perish in minutes without it.)
Can you be more specific about exactly what you're doing (what OS, exact
Eclipse version, exact repro steps)?
Does it happen if you create a fresh workspace, fresh project, and fresh
file?
Do you have any third-party plugins installed that might be interfering?
Are there any errors reported in the error log (PDE Runtime Perspective ->
Errors View)?
Does it fail regardless of how you try to access the command, i.e., from the
menu as well as from keyboard shortcut?
FUDForum. Page generated in 0.02528 seconds
