Re: Rearrange dropins folder fails [message #333918 is a reply to message #333914] |
Tue, 13 January 2009 21:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: ekkehard.gentz-software.de
Kai Schlamp schrieb:
> Hello!
> I want to rearrange my dropins folder, but after rearranging the plugins
> are not found anymore (the new layout is supported and works perfectly
> in a fresh eclipse install).
> By example:
> I have my CDO Plugins installed in /dropins/eclipse/* (works fine) and
> now move them to /dropins/cdo/eclipse/*.
> But after doing that and restarting Eclipse (3.5M4) I get those errors
> in the log:
> ProvisionException
> No repository found at
> file:/C:/Users/superuser/eclipse/eclipse/eclipse_3.5_cdo_2/d ropins/cdo
> If I unzip just a fresh Eclipse SDK and put the same directory layout in
> the dropins folder everything works fine.
> I tried to start Eclipse with the -clean argument, but this doesn't help.
> Any suggestions how to rearranging the dropins folder?
> Best regards,
> Kai
Kai,
perhaps this helps you:
1. remove all plugins you want to re-arrange from dropins folder
2. start -clean and quit
3. put plugins into new location, use a folder name you never used
before inside dropins with this eclipse installation
4. start -clean
if you're in luck the plugins are there
ekke
Re: Rearrange dropins folder fails [message #333935 is a reply to message #333918] |
Wed, 14 January 2009 13:23 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: nospam_kowalskilee.gmail.com
>> Hello!
>> plugins are not found anymore (the new layout is supported and works
>> perfectly in a fresh eclipse install).
>> By example:
>> in the log:
>> ProvisionException
>> in the dropins folder everything works fine.
>> Best regards,
>> Kai
> Kai,
> 4. start -clean
> ekke
Hi ekke,
One pervasive question about p2 and dropins is why it doesn't seem to
completely "clean" just by using -clean.
I mean, why is this part of your step 3 necessary: "use a folder name
you never used before inside dropins with this eclipse installation".
I would have expected that if I did your step 1 and 2 (remove and
clean), then I could go ahead and use a folder name that I *have* used
before. Wouldn't it all be "clean" by that point?
--Lee Anne
FUDForum. Page generated in 0.03698 seconds
