[Common Navigator]Re: Common Navigator DND [message #334023 is a reply to message #334019] |
Fri, 16 January 2009 00:25 |
Adil Fulara Messages: 14 Registered: July 2009 |
Junior Member |
I am actually trying to drag an object from one common navigator and
drop it onto another common navigator.
I thought at the drag side, we need to get hold of the drag object and
have a reference to it on the drop side. Hence i added the dragAssistant
and dropAssitant.
So as per your reply, if i understand correctly, i just need to add a
dropAssistant at the receiving side and handle the drop?
~Adil.
Francis Upton (News) wrote:
> What are you trying to accomplish by adding the drag assistant?
> In general, if you are using the LocalSelectionTransferType (which can
> cover anything selected by the navigator), then you don't need to do
> anything on the drag side.
> You only need to add the special drag support if you want a different
> transfer type.
> Francis
> (ps - please reply to the newsgroup, but you may copy me on the reply so
> I get it quickly).
> Adil Fulara wrote:
>> Just wanted to provide an update.
>> 1.
>> I added dragAssistant to my viewer Extension and supplied the class.
>> This class is a subclass of CommonDragAdapterAssistant
>> So when i start to drag, the getSupportedTransferTypes() method is
>> called.
>> The problem now is setDragData() method is never called where i could
>> set the get hold of the data to be dragged.
>> Any help would be good. Thanks.
>> ~Adil.
>> Adil Fulara wrote:
>>> Hi,
>>> I am trying to add Drag and Drop support to my CN implementation.
>>> Is there any tutorial / guide to get started on this particular issue?
>>> I read on eclipse help that CommonDropAdapterAssistant and
>>> CommonDragAdapterAssistant are the classes to start with but am a
>>> little lost.
>>> Any help would be appreciated.
>>> Thank you,
>>> ~Adil.
Re: [Common Navigator]Re: Common Navigator DND [message #334027 is a reply to message #334023] |
Fri, 16 January 2009 03:05 |
Francis Upton IV Messages: 472 Registered: July 2009 Location: Oakland, CA |
Yes, that's all you should need. And if you are using resources, then
you don't even need that.
> and dropAssitant.
> ~Adil.
>> transfer type.
>> Francis
>> so I get it quickly).
>>> 1.
>>> called.
>>> ~Adil.
>>> Adil Fulara wrote:
>>>> Hi,
>>>> little lost.
>>>> Thank you,
>>>> ~Adil.
Common Navigator Framework section in Platform Plugin Developer Guide
(Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Platform UI Committer for Common Navigator
http://wiki.eclipse.org/index.php/Common_Navigator_Framework
http://help.eclipse.org/galileo/topic/org.eclipse.platform.d oc.isv/guide/cnf.htm
Re: [Common Navigator]Re: Common Navigator DND [message #334029 is a reply to message #334027] |
Fri, 16 January 2009 03:57 |
Junior Member |
Great. This is awesome.
It works fine. Thanks very much Francis.
Guess the SWT DND tutorial took me on the wrong path and confused me.
I now can handle DnD in my views.
~Adil.
>> dragAssistant and dropAssitant.
>> ~Adil.
>>> can cover anything selected by the navigator), then you don't need to
>>> do anything on the drag side.
>>> transfer type.
>>> Francis
>>>> 1.
>>>> called.
>>>> could set the get hold of the data to be dragged.
>>>> ~Adil.
>>>> Adil Fulara wrote:
>>>>> Hi,
>>>>> little lost.
>>>>> Thank you,
>>>>> ~Adil.
FUDForum. Page generated in 0.04381 seconds
