Home » Eclipse Projects » Eclipse Platform » why does the jvm terminate when i open eclipse?
why does the jvm terminate when i open eclipse? [message #333870] Sun, 11 January 2009 19:44 Go to next message
Originally posted by: automatic.javalobby.org
just downloaded eclipse and it gets terminated with jvm error codes, i first tried it with java 6, and switched back to java 5, and played with permMaxSize
this happened also with europa-winter.
Re: why does the jvm terminate when i open eclipse? [message #333873 is a reply to message #333870] Sun, 11 January 2009 20:46 Go to previous messageGo to next message
Elhanan,
What are you doing to ensure that a specific JRE is used? (As opposed
to the one that happens to be the system default installed in system32.)
Ed Merks
Re: why does the jvm terminate when i open eclipse? [message #333881 is a reply to message #333873] Mon, 12 January 2009 14:04 Go to previous message
On 1/11/2009 3:46 PM, Ed Merks wrote:
> Elhanan,
> What are you doing to ensure that a specific JRE is used? (As opposed to
>> with permMaxSize
See http://wiki.eclipse.org/Eclipse.ini for how to specify the JVM and
memory parameters.
Hope this helps,
Eric
Previous Topic:Team question - what to check-in in SCM system
Next Topic:Contribute command menu item to "legacy" menu?
Current Time: Thu Dec 26 20:14:38 GMT 2024
Powered by FUDForum. Page generated in 0.04014 seconds
