Home » Eclipse Projects » Eclipse Platform » TextEditor (sourceViewer) in a view
TextEditor (sourceViewer) in a view [message #333815] Wed, 07 January 2009 10:26 Go to next message
Hugues Rérolle is currently offline Hugues RérolleFriend
Member
Hi all,
I want to develop a text editor in a view (for editing selected text in
workbench).
Anyone has a idea to achieve this ?
I've used SourceViewer with SourceViewerConfiguration.
Only syntax Cloring worked, but I don't know how to active other stuff
(contentAssist, contentFormatter, etc), furthermore I want to active
drag'n drop.
Thanks in advance,
Hugues
Re: TextEditor (sourceViewer) in a view [message #333817 is a reply to message #333815] Wed, 07 January 2009 11:21 Go to previous messageGo to next message
Dani Megert is currently offline Dani MegertFriend
Hugues Rérolle wrote:
> Hi all,
> in workbench).
You have to provide the formatter and the content assistant in your
source viewer configuration.
Dani
> furthermore I want to active drag'n drop.
> Thanks in advance,
> Hugues
Re: TextEditor (sourceViewer) in a view [message #333818 is a reply to message #333817] Wed, 07 January 2009 14:39 Go to previous message
Member
>> Hi all,
>> in workbench).
> Dani
Thanks Dani,
I've already tried by using JavaSourceViewerConfiguration, but only
syntax coloring worked.
public class TestCodeEditor extends ViewPart {
private SourceViewer viewer;
private IDocument doc;
public TestCodeEditor() {
public void createPartControl(Composite parent) {
viewer = new SourceViewer(parent, new VerticalRuler(0), SWT.V_SCROLL
| SWT.MULTI | SWT.H_SCROLL | SWT.BORDER);
doc = new Document();
doc.set("");
viewer.setDocument(doc);
JavaSourceViewerConfiguration javaConf = new
(org.eclipse.jdt.ui.JavaUI.getColorManager(),
org.eclipse.jdt.ui.PreferenceConstants.getPreferenceStore(), null,
null);
viewer.configure(javaConf);
Hugues
>> Thanks in advance,
>> Hugues
Previous Topic:how to dynamically create a instance of a class in eclipse plugin
Next Topic:Tables and Checkboxes
Current Time: Fri Nov 08 22:01:39 GMT 2024
Powered by FUDForum. Page generated in 0.03146 seconds
