Home » Eclipse Projects » Eclipse Platform » how to dynamically create a instance of a class in eclipse plugin
how to dynamically create a instance of a class in eclipse plugin [message #333805] Tue, 06 January 2009 15:40 Go to next message
I have some code which runs in J2SE well for dynamically loading an
instance of a class but it does not work in eclipse plugin. What I can do
to make the code work in eclipse too.
In J2SE, the code is as
ClassLoader loader = getClass().getClassLoader();
Class c = null;
try {
c = loader.loadClass(className);
} catch (ClassNotFoundException cnfe) {
throw new ParsingException("couldn't load class " + className,
cnfe);
try {
instance = c.newInstance();
} catch (InstantiationException ie) {
throw new ParsingException("couldn't instantiate " + className
+ " with empty constructor", ie);
} catch (IllegalAccessException iae) {
throw new ParsingException("couldn't get access to instance " +
"of " + className, iae);
Can I still use newInstance() method?
thanks
hao
Re: how to dynamically create a instance of a class in eclipse plugin [message #333806 is a reply to message #333805] Tue, 06 January 2009 15:45 Go to previous messageGo to next message
Is newInstance or loadClass failing?
It's very likely the the OSGi-ClassLoader in your plug-in is not seeing
the class you want to load. Once loaded newInstance should work.
Tom
> do to make the code work in eclipse too.
> Class c = null;
> try {
> cnfe);
> try {
> thanks
> hao
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: how to dynamically create a instance of a class in eclipse plugin [message #333811 is a reply to message #333806] Tue, 06 January 2009 20:40 Go to previous messageGo to next message
class loading failed. How could I make sure OSGi-ClassLoader finds the
class?
thanks
hao
Re: how to dynamically create a instance of a class in eclipse plugin [message #333812 is a reply to message #333811] Tue, 06 January 2009 20:51 Go to previous message
You need to add the plugin / bundle which holds it as a required-bundle
or add an import-package declaration to your MANIFEST.MF.
Tom
> class?
> thanks
> hao
Previous Topic:Feature-based product and specifying what plug-ins to include
Next Topic:TextEditor (sourceViewer) in a view
Current Time: Sun Apr 27 00:44:48 EDT 2025
Powered by FUDForum. Page generated in 0.02550 seconds
