Re: Plugin configuration by start file [message #333787 is a reply to message #333785] |
Mon, 05 January 2009 21:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: coolsnoopy.gmx.net
Christian wrote:
> Hallo, Is there a way to start eclipse with a predefined set of plugins
> and perspectives?
> I would start eclipse for Java with other plugins and perspectives than
> for PHP. While I work with Java I don't need the plugins for PHP so they
> can be inactive. Is that possible to configure the active plugins by
> start file or the like?
2 possibilities here:
a) different perspectives
use 2 different workspaces: e.g. "workspace-php" and "workspace-java".
By the way: avoid blanks in workspace-folder names, some tools/plugins
work improper else...
b) different / other plugins
No really simple way: you just have do install eclipse twice (or even
more times). I do the same for very different projects. That may end up
in 2 or 3 installations. The problem is to transfer settings that should
be the same in every installation. But it's possible.
FUDForum. Page generated in 0.03236 seconds
