Termination of Debugging session hangs PDT [message #1783927] |
Tue, 20 March 2018 13:21 |
saurav sarkar Messages: 428 Registered: July 2009 |
Hi All,
I am using PDT 5.2.0
Eclipse Java EE IDE for Web Developers.
Version: Oxygen.2 Release (4.7.2)
Build id: 20171218-0600
Bitnami PHP MAMP stack 7.1.15-0
PHP 7.1.15 and Apache 2.4.29
Xdebug values in php.ini
[XDebug]
;; Only Zend OR (!) XDebug
zend_extension="/usr/local/opt/php71-xdebug/xdebug.so"
xdebug.remote_enable=true
xdebug.remote_host=127.0.0.1
xdebug.remote_port=9000
xdebug.remote_handler=dbgp
xdebug.profiler_enable=1
xdebug.profiler_output_dir=/tmp
I have created a debug configuration pointing to my MAMP stack server.
Debug session is launching fine and BPs are hit. But when i try to terminate the debug session eclipse gets hanged completely and i don't have any other option other than to kill eclipse.
I keep getting this in error logs when i switch to debug view from the php editor
at org.eclipse.wst.sse.ui.internal.debug.ToggleBreakpointsTarget.canToggleLineBreakpoints(ToggleBreakpointsTarget.java:60)
at org.eclipse.debug.internal.ui.actions.breakpoints.RetargetToggleLineBreakpointAction.canPerformAction(RetargetToggleLineBreakpointAction.java:38)
at org.eclipse.debug.internal.ui.actions.RetargetAction.isTargetEnabled(RetargetAction.java:245)
at org.eclipse.debug.internal.ui.actions.RetargetAction.partActivated(RetargetAction.java:175)
at org.eclipse.ui.internal.PartService$1.run(PartService.java:83)
at org.eclipse.ui.internal.PartService.partActivated(PartService.java:80)
at org.eclipse.ui.internal.WorkbenchWindow$WWinPartService.partActivated(WorkbenchWindow.java:3010)
at org.eclipse.ui.internal.WorkbenchPage$14.run(WorkbenchPage.java:4990)
at org.eclipse.ui.internal.WorkbenchPage.firePartActivated(WorkbenchPage.java:4987)
at org.eclipse.ui.internal.WorkbenchPage.access$19(WorkbenchPage.java:4975)
at org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partActivated(WorkbenchPage.java:212)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$3.run(PartServiceImpl.java:250)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.firePartActivated(PartServiceImpl.java:247)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:756)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.switchPerspective(PartServiceImpl.java:640)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:102)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.lambda$0(LazyStackRenderer.java:68)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:144)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4871)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:212)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:52)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:135)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:1)
at org.eclipse.e4.ui.workbench.addons.perspectiveswitcher.PerspectiveSwitcher$4.widgetSelected(PerspectiveSwitcher.java:543)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4258)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1502)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1525)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1510)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1314)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4082)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3699)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1150)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
Best Regards,
Saurav
My Blog http://codifyit.blogspot.com/
Follow me: http://twitter.com/sauravs
[Updated on: Tue, 20 March 2018 16:08] Report message to a moderator
FUDForum. Page generated in 0.02673 seconds
