Home » Eclipse Projects » Eclipse Platform » BracketInserter, "mirrored" text in brackets
BracketInserter, "mirrored" text in brackets [message #333732] |
Tue, 30 December 2008 08:13  |
This is kind of weird... I borrowed the following code from
BracketInserter verbatim. It does close parens, braces, etc. and puts the
cursor in between the characters, but when I type I get 2 of whatever I
type - one before the cursor, one after, resulting in "mirrored" text. If
I type "abc", I get "abccba". FWIW, I yanked the code from a 3.4 install
and applied it to a 3.2 plugin I'm working on. This is on Windows XP,
though it shouldn't matter. Anyone understand LinkedModeModel well enough
to comment, please?
Bret
LinkedModeModel model = new LinkedModeModel();
model.addLinkingListener(this);
model.addGroup(group);
model.forceInstall();
level.fOffset = offset;
level.fLength = 2;
// set up position tracking for our magic peers
if (fBracketLevelStack.size() == 1) {
document.addPositionCategory(CATEGORY);
document.addPositionUpdater(fUpdater);
level.fFirstPosition = new Position(offset , 0);
level.fSecondPosition = new Position(offset + 1, 1);
document.addPosition(CATEGORY, level.fFirstPosition);
document.addPosition(CATEGORY, level.fSecondPosition);
level.fUI = new EditorLinkedModeUI(model, sourceViewer);
level.fUI.setSimpleMode(true);
level.fUI.setExitPolicy(new ExitPolicy(closingCharacter,
getEscapeCharacter(closingCharacter),
fBracketLevelStack));
level.fUI.setExitPosition(sourceViewer, offset + 2, 0,
Integer.MAX_VALUE);
level.fUI.setCyclingMode(LinkedModeUI.CYCLE_NEVER);
level.fUI.enter();
IRegion newSelection = level.fUI.getSelectedRegion();
Re: BracketInserter, "mirrored" text in brackets [message #333774 is a reply to message #333732] |
Mon, 05 January 2009 03:34  |
Bret,
did you also use an ExclusivePositionUpdater for your position updater?
-tom
> the cursor in between the characters, but when I type I get 2 of
> whatever I type - one before the cursor, one after, resulting in
> "mirrored" text. If I type "abc", I get "abccba". FWIW, I yanked the
> code from a 3.4 install and applied it to a 3.2 plugin I'm working on.
> This is on Windows XP, though it shouldn't matter. Anyone understand
> LinkedModeModel well enough to comment, please?
> Bret
> level.fLength = 2;
> Integer.MAX_VALUE);
> level.fUI.enter();
Current Time: Fri Apr 25 22:33:19 EDT 2025
Powered by FUDForum. Page generated in 0.02405 seconds
