Home » Eclipse Projects » Eclipse Platform » Convert class files in java code
Convert class files in java code [message #333676] Mon, 22 December 2008 15:28 Go to next message
Hi all,
I use my own content assist and want to use methods in class files. Is
there a possibility to convert in eclise the binary code in java source
code?
Thanks!
Re: Convert class files in java code [message #333677 is a reply to message #333676] Mon, 22 December 2008 19:34 Go to previous messageGo to next message
Artur,
I'm pretty sure such a thing isn't built in. If you don't have the
source code for something (you can specify source attachments for jars),
you probably aren't meant to have it...
Artur Zeiler wrote:
> Hi all,
> source code?
> Thanks!
Re: Convert class files in java code [message #333678 is a reply to message #333676] Mon, 22 December 2008 20:00 Go to previous messageGo to next message
Artur Zeiler wrote:
> Hi all,
> source code?
You can try using a decompiler, such as JAD. There is a plug-in for
JAD, called JADClipse, that will let you view .class files as Java
source, with some limitations.
As Ed suggests, you need to be careful of licensing issues; it is not
always legal to decompile binaries.
Re: Convert class files in java code [message #333679 is a reply to message #333677] Mon, 22 December 2008 20:06 Go to previous messageGo to next message
Sure that there is no way?
I tried it with
org.eclipse.jdt.internal.compiler.classfmt.ClassFileReader, but i only get
the method names.
I can't find a way to get the method body.
Re: Convert class files in java code [message #333680 is a reply to message #333678] Mon, 22 December 2008 20:22 Go to previous messageGo to next message
Thanks!
I'm workin on a project which should make it possible to reuse code that a
user already implemented. So there aren't problems with the license. I'm
searching for a way to get the source code without any decompiler. My
problem is, that i have to use eclipse for that, without any usage of
other tools.
Thanks!
Re: Convert class files in java code [message #333681 is a reply to message #333680] Mon, 22 December 2008 21:01 Go to previous message
Artur,
Making use of source attachments (a jar/zip file with all the
corresponding sources) is the way to go then.
Artur Zeiler wrote:
> Thanks!
> that a user already implemented. So there aren't problems with the
> license. I'm searching for a way to get the source code without any
> decompiler. My problem is, that i have to use eclipse for that,
> without any usage of other tools.
> Thanks!
Previous Topic:[JFace] bug in snippet 019
Next Topic:problem with the message: Cannot find 'org.junit.Test' on project build path
Current Time: Thu Oct 30 01:16:53 EDT 2025
Powered by FUDForum. Page generated in 0.12128 seconds
