Home » Eclipse Projects » Eclipse Platform » How can I change the location where the project files are stored?
How can I change the location where the project files are stored? [message #333612] Thu, 18 December 2008 07:40 Go to next message
I am working on a project where only a few developpers are using eclipse.
The project is stored on an SVN database and I wanted to store the project
files on the database to share it with the other eclipse users working on
the project.
Unfortunately, the non eclipse developers are complaining about the fact
that the eclipse project files (.project, .cproject, .settings,
pydevproject) are located at the project root. They would like to see
them in a specific projectroot/workspace/eclipse directory where other
tools workspace descriptions are stored.
My other solution is to remove those files from SVN and SVNignore them,
but I would really like to have it available to convince the other users
that eclipse is a better choice than their respective vi/vim/XXedit
solutions.
Thanks for your help,
Louis
Re: How can I change the location where the project files are stored? [message #333618 is a reply to message #333612] Thu, 18 December 2008 09:53 Go to previous messageGo to next message
> eclipse. The project is stored on an SVN database and I wanted to store
> the project files on the database to share it with the other eclipse
> users working on the project.
> solutions.
This has been requestes and discussed at length. Unfortunately, it is
not a trivial issue because Eclipse projects need to be self-describing
and thus the .project file (and its friends) needs to be in a consistent
(non-configurable) location.
Here are some bugs I found relating to this issue; feel free to
contribute your own comments or votes or, even better, design ideas and
code patches:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=76695
https://bugs.eclipse.org/bugs/show_bug.cgi?id=78438
https://bugs.eclipse.org/bugs/show_bug.cgi?id=42875
https://bugs.eclipse.org/bugs/show_bug.cgi?id=72301
Hope this helps,
Eric
Re: How can I change the location where the project files are stored? [message #333633 is a reply to message #333618] Thu, 18 December 2008 17:43 Go to previous message
Originally posted by: wegener.cboenospam.com
"Eric Rizzo" <eclipse-news@rizzoweb.com> wrote in message
news:gido38$vpr$1@build.eclipse.org...
> > solutions.
> code patches:
> Hope this helps,
> Eric
You can locate these files in a directory other than the root by using
linked resources. Create your project in the projectroot/workspace/eclipse
directory. Define a Path Variable
(Window->Preferences->General->Workspace->Linked Resources) to point to the
root of your project (this allows relative positioning on each developers
PC). Then use the Advanced section of New->Folder to expand on the Path
Variable to point to your source directories.
The .project, .classpath, etc files will then be stored in the
projectroot/workspace/eclipse directory but you will still be able to share
the projects.
Tip. to set enterprise wide project settings select the Enable project
specific settings on the Properties page for your project. This will save
the settings in a .settings directory in your projectroot/workspace/eclipse
directory. You can then check them into SVN and everyone who checks the
project out will have the same settings. You can copy the .settings
directory to new Eclipse projects when you create them to keep the settings
consistent across projects.
Previous Topic:p2: problem with permissions.properties on linux
Next Topic:Changing model for a TableViewer in a View
Current Time: Fri Nov 07 07:18:02 EST 2025
Powered by FUDForum. Page generated in 0.02880 seconds
