Re: Configuration of XSD/WSDL errors in Eclipse [message #333481 is a reply to message #333480] |
Sat, 13 December 2008 15:42 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Ed Merks![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ed.merks%40gmail.com) Messages: 33183 Registered: July 2009 |
Thomas,
It's probably best to ask on the WTP newsgroup, though it sounds like
your schemas at least are not well-defined and ought to be fixed; after
all, hiding error messages doesn't make errors themselves go away...
Thomas Wiedmann wrote:
> Hello,
> in Eclipse 3.2.2 in xsd and wsdl files e. g. following errors are
> indicated:
> The markup in the document following the root element must be
> well-formed.
> WSDL: The body part does not have a type defined and has been
> specified for a SOAP body with its use encoded. When use is encoded on
> a SOAP body, all parts defined must only contain a valid type.
> XSD: An element reference may only have an id, minOccurs, or maxOccurs
> XSD: Attribute reference
> 'http://schemas.xmlsoap.org/soap/encoding/#arrayType' is unresolved
> ... and others
> How, i. e. where can the error level of these errors be configured in
> Eclipse, that they are indicated either as warning only or even be
> ignored (such as other error cases)?
> I tried to reach this by switching off all checkboxes at "WSDL
> Validator" and "XML Schema Validator" at the rubric Validation in
> Window/Preferences... - but no changes were observed, so these
> messages still appeared as errors.
> Thomas Wiedmann
Ed Merks
Re: Configuration of XSD/WSDL errors in Eclipse [message #333482 is a reply to message #333480] |
Sat, 13 December 2008 23:49 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
> Hello,
> Window/Preferences... - but no changes were observed, so these messages
Short answer you can't yet. I think their is an open bug request for
this but I'm not positive on that.
Dave
FUDForum. Page generated in 0.03303 seconds
