Home » Eclipse Projects » Eclipse Platform » Select element in TableViewer starting with a specific character
Select element in TableViewer starting with a specific character [message #333468] Fri, 12 December 2008 06:37 Go to next message
when the user presses for example the key "k" the tableviewer should
iterate over all rows in the table where the content of a specific
column starts with a "k". Basically the same as in the Windows Explorer.
I tried to write my own KeyListener. It works, but something is
happening in the background: My machine "beeps" when pressing a key.
Thank you!
Re: Select element in TableViewer starting with a specific character [message #333469 is a reply to message #333468] Fri, 12 December 2008 06:48 Go to previous messageGo to next message
Florian Bartels wrote:
> Hello,
Are you talking about the first column or any arbitrary column? The
first column seems to work fine for me. It'll search my table's first
column properly. I do not get a beep and did not attach any KeyListeners.
Remy
Re: Select element in TableViewer starting with a specific character [message #333470 is a reply to message #333469] Fri, 12 December 2008 07:14 Go to previous message
Am 12.12.2008 12:48, schrieb Remy Chi Jian Suen:
>> Hello,
> Remy
Unfortunately it is not the first column in which the name/label is
shown. So it does not work "out of the box".
Florian
Previous Topic:apache.commons.logging 1.0.4 with two different build dates
Next Topic:Question: the software items you selected may not be valid...bug?
Current Time: Tue Nov 04 20:28:54 EST 2025
Powered by FUDForum. Page generated in 0.03432 seconds
