Re: [Databinding] EL support in JFace Databinding? [message #333366 is a reply to message #333365] |
Fri, 05 December 2008 18:48 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
You should check out the work in this enhancement request:
https://bugs.eclipse.org/195222
On 12/5/2008 12:36 PM, Jacek Furmankiewicz wrote:
> Coming from the Swing BeansBinding, I am used to being able to use EL
> expression when doing binding, e.g.
> "myProperty.itsProperty.anotherNestedChildProperty".
> I cannot find the equivalent way of doing it in JFace databinding...it
> seems you have to create the observables on the "final" object in this
> hierarchy...there's no way to specify a nested hierarchy via an EL
> expression.
> I offer this functionality in my Java SwingBuilder library:
> http://code.google.com/p/javabuilders/wiki/JavaBuilderDataBi nding
> and would like to offer the same level of functionality in the Java
> SWTBuilder I am currently working on.
> Thanks
FUDForum. Page generated in 0.03278 seconds
