Custom Editor Saving File causes cursor position to be reset [message #333303] |
Wed, 03 December 2008 17:26 |
Mike Jackson Messages: 128 Registered: July 2009 |
I my custom editor CMakeEditor which extends from TextEditor
(cmakeed.sourceforge.net) when the user "saves" the document, the
cursor is reset to the top of the file which isn't exactly friendly. I
have some code to stop this from happening but it seems awfully like a
"kludge" rather than doing it the "correct" way.
Here is my current code foe the doSave(IProgressMonitor prog) method:
public void doSave(IProgressMonitor prog)
super.doSave(prog);
UIPlugin.getDefault().getCMakePartitionScanner().setDefaultS cannerRules();
IDocument document = this.getSourceViewer().getDocument();
if (document instanceof IDocumentExtension3) {
IDocumentExtension3 extension3 = (IDocumentExtension3) document;
IDocumentPartitioner partitioner =
extension3.getDocumentPartitioner(UIPlugin.CMAKE_PARTITIONIN G);
if (partitioner != null)
partitioner.disconnect();
partitioner.connect(document);
// Reinit the syntax coloring
final SourceViewer sourceViewer = (SourceViewer)getSourceViewer();
int line = sourceViewer.getTopIndex();
ITextSelection sel = (ITextSelection)sourceViewer.getSelection();
sourceViewer.unconfigure();
final CMakeEditorConfiguration config =
new CMakeEditorConfiguration(this.colorMgr);
sourceViewer.configure(config);
sourceViewer.refresh();
sourceViewer.setTopIndex(line);
sourceViewer.setSelectedRange(sel.getOffset(), sel.getLength() );
UIPlugin.getDefault().getCMakePartitionScanner().removeUserV ariableRule();
Any help would be greatly appreciated. Or point me to an example that
has the desired behavior and I can try an work from that.
Mike Jackson
BlueQuartz Software
www.bluequartz.net
FUDForum. Page generated in 0.02676 seconds
