Home » Eclipse Projects » Eclipse Platform » [Databinding] ObservableMapLabelProvider + Tooltips
[Databinding] ObservableMapLabelProvider + Tooltips [message #333218] Mon, 01 December 2008 06:24 Go to next message
im working on tableviewer and databinding. everything works great except
tooltips. i didn't find any way how to make tooltips with an
ObservableMapLabelProvider possible.
maybe someone could point my to the right direction.
thank you
lukas
Re: [Databinding] ObservableMapLabelProvider + Tooltips [message #333220 is a reply to message #333218] Mon, 01 December 2008 06:49 Go to previous messageGo to next message
The ColumnViewerToolTipSupport recalculates the tooltip everytime before
it is shown so I don't think you need to use Databinding there. Or was
ColumnViewerToolTipSupport the thing you searched for.
See [1] for examples.
Tom
[1]http://wiki.eclipse.org/JFaceSnippets
Lukas Myslivec schrieb:
> Hello,
> thank you
> lukas
Re: [Databinding] ObservableMapLabelProvider + Tooltips [message #333227 is a reply to message #333220] Mon, 01 December 2008 10:16 Go to previous messageGo to next message
i am using databinding for binding the content to my tableviewer. so the
labelprovide is ObservableMapLabelProvider which extends LabelProvider and
not celllabelprovider which i dont understood.
thank very much you for your hint ColumnViewerToolTipSupport. but this is
not working.
some other ideas with tableviewer databinding and tooltips?
thank you
lukas
Re: [Databinding] ObservableMapLabelProvider + Tooltips [message #333237 is a reply to message #333227] Mon, 01 December 2008 10:50 Go to previous message
Use this one [1] it subclasses ColumnLabelProvider and
ColumnViewerToolTipSupport needs a CellLabelProvider.
Tom
[1] http://publicsvn.bestsolution.at/repos/java/at.bestsolution. dataforms/trunk/src/at/bestsolution/dataforms/util/viewers/G enericObservableMapCellLabelProvider.java
> Hello,
> and not celllabelprovider which i dont understood.
> is not working.
> thank you
> lukas
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Previous Topic:Running command in another plugin
Next Topic:Implementing a File Listener in a plugin
Current Time: Wed Apr 23 23:33:14 EDT 2025
Powered by FUDForum. Page generated in 0.02677 seconds
