| Show/hide view declararively [message #333117] |
Wed, 26 November 2008 03:02  |
Hy.
Is there a way to declare the visibility of a view declaratively?
Background: My RCP app uses a database for storing the whole data. If
the app is not connected to the database, then instead of the normal
views a hint should be presented to the user, that he should connect to
the database first.
As there is no glasspane in SWT (which would be the best option for this
task), I added another view with a "Please connect to database" message
on it and shift between this view and the normal views dependent on the
database connection. (Any better ideas for such a case?)
At the moment I do this fully programmatically, but I wonder if there is
a way to do this declaratively. Perhaps with the use of conditional
property testers, like the declaration for enabling/disabling handlers.
Kai
| Re: Show/hide view declararively [message #333150 is a reply to message #333129] |
Wed, 26 November 2008 17:31  |
Hello Daniel.
Thanks for the help.
I think I will go with your first alternative, even if it is not so nice
as there are minimum three views per perspective, and every view will
then have an error-case composite.
I also thought about implementing your second alternative with views.
Like a "view visible when" extension point. But this is also a bit
cumbersome.
I really hope there will be one day something like a glasspane for SWT.
Greetings from Mainz to Bremen :-)
Kai
>> to the database first.
>> this task), I added another view with a "Please connect to database"
>> message on it and shift between this view and the normal views
>> dependent on the database connection. (Any better ideas for such a case?)
> What about the *same* view, but with different top composite, depending
> on the situation? The "error-case" composite could have a totally
> different look-and-feel (including a message or some such).
> Alternatively, you could do the same thing via your own extension point.
> This extension point could also reuse the core-expression's (There
> exists a programmer API for that), so you could define (run-time)
> conditions under which the corresponding composite is instantiated.
> HTH & Greetings from Bremen,
> Daniel Krügler
FUDForum. Page generated in 0.55528 seconds
