Home » Eclipse Projects » Eclipse Platform » Wwitch between Groups of Key Bindings Dynamically
Wwitch between Groups of Key Bindings Dynamically [message #333088] Tue, 25 November 2008 06:04 Go to next message
IBindingServe says "If you are trying to switch between groups of bindings
dynamically, you should be using contexts.", how would one go about this?
I am trying to get my bindings and only my bindings to go into the
ctrl+shift+L cheat sheet.
I tried a couple of strategies and most of them resulted in an empty key
bindings cheat sheet.
For example I created my own scheme and my own BindingManager and then I
set the BindingManager scheme and at the end I called
bindingService.savePreferences.
Do I need to work with contexts? Or am I doing something else wrong?
This is essentially what I am doing:
IBindingService bindingService = (IBindingService) PlatformUI
getWorkbench().getAdapter(IBindingService.class);
BindingManager localChangeManager = new BindingManager(
new ContextManager(), new CommandManager());
try {
Scheme scheme = bindingService.getScheme("newscheme");
localChangeManager.setActiveScheme(scheme);
} catch (final NotDefinedException e) {
throw new Error(
"There is a error"); //$NON-NLS-1$
try {
bindingService.savePreferences(
localChangeManager.getActiveScheme(), localChangeManager
.getBindings());
} catch (IOException e) {
// TODO Auto-generated catch block
e.printStackTrace();
Perhaps I am defining the scheme wrong, when I do setActiveScheme, it
throws an exception about the parent identifier. Ideally I want to parent
identifier, but if set to org.eclipse.ui.defaultAcceleratorConfiguration,
I am getting the same problem.
this is my scheme:
<scheme
name="newscheme"
description="newscheme"
parentId = "org.eclipse.ui.defaultAcceleratorConfiguration"
id="newscheme"/>
thanks
Re: Wwitch between Groups of Key Bindings Dynamically [message #333139 is a reply to message #333088] Wed, 26 November 2008 13:49 Go to previous message
What are you trying to do, anyway? A local BindingManager is useful if
you are writing the equivalent of the keybinding preference page. But
it requires a lot of setup before it works correctly.
Take a look at
org.eclipse.ui.internal.keys.model.KeyController.loadModelBa ckend(IServiceLocator)
which takes tries to fill in a blank BindingManager from the
IBindingService.
PW
Paul Webster
Previous Topic:how to terminate new process created via Runtime.exec()
Next Topic:How to remove/replace the default key binding scheme
Current Time: Wed Oct 22 23:57:42 EDT 2025
Powered by FUDForum. Page generated in 0.04566 seconds
