How can I upload the file named "Administrator.java" to CVS server [message #33793] |
Mon, 14 March 2005 04:10 |
Originally posted by: wx_new.yahoo.co.jp
How can I upload the file named "Administrator.java" to CVS server.
if I change the name to another else, It is no any problem, but now I
should use that name.
Perhaps CVS server is Using the word of "administrator" I think, but is
there no way to upload the file named "Administrator.java" to CVS server?
help me please ,thanks,
/ wx
Re: How can I upload the file named "Administrator.java" to CVS server [message #33994 is a reply to message #33793] |
Mon, 14 March 2005 13:55 |
Originally posted by: myersj.gmail.com
I doubt there's a limitation in CVS preventing you from checking in this
file. What is the exact error message you receive when you attempt to
check in Administrator.java to cvs?
- Jeff
wangxuan wrote:
> / wx
Re: How can I upload the file named "Administrator.java" to CVS server [message #34547 is a reply to message #33994] |
Tue, 15 March 2005 07:19 |
when "cvs commit" command execute, error happened at server.
error message :
BPW5.0: assertion "key != NULL" failed: file
"/usr/src/cvs/cvs-1.11.5/src/hash.c", line 312
BPW5.0: cvs [server aborted]: received abort signal
by the way: BPW5.0 is my project
thanks for your help.
> - Jeff
> wangxuan wrote:
>> / wx
Re: How can I upload the file named "Administrator.java" to CVS server [message #35257 is a reply to message #34547] |
Tue, 15 March 2005 23:56 |
Originally posted by: SamMesh.gmail.com
Probably, here is your *case* :)
http://www.massconfusion.com/tim/notes/cvs_1.11.txt
Look for "!= NULL" (at the end).
HTH,
Sam Mesh
> error message :
>> this file. What is the exact error message you receive when you
>> attempt to check in Administrator.java to cvs?
>> - Jeff
>> wangxuan wrote:
>>> Hi,
>>> is there no way to upload the file named "Administrator.java" to CVS
>>> server?
FUDForum. Page generated in 0.05126 seconds
