Re: New project wizard > right-click menu > always enabled [message #333243 is a reply to message #333057] |
Mon, 01 December 2008 23:57 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Francis Upton IV![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=francisu%40ieee.org) Messages: 472 Registered: July 2009 Location: Oakland, CA |
WOuld you mind filing a bug about this to platform UI, I have run into
this problem myself (looking for just having "true" as a value), and we
should make it abundantly clear in the documentation how to easily do this.
Francis
Rahul Kamdar wrote:
> Ok, I managed to get through this one. Keeping the enablement empty does the
> trick (<enablement></enablement>) it seems.
> Rahul
> "Rahul Kamdar" <rtkamdar@kamdars-india.com> wrote in message
> news:gfu5v8$7hl$1@build.eclipse.org...
>> I have a wizard for new project. I want to make this wizard always
>> available in the right-click > New menu. From what I read around the web,
>> it seems it's a must to use the commonWizard element under the
>> navigatorContent extensionPoint. I need to know what do I provide in the
>> <enablement> clause to make it always enabled. I tried using count with
>> value=* but it throws:
>> org.eclipse.core.runtime.CoreException: The default variable is not of
>> type java.util.Collection. Failed expression:
>> org.eclipse.core.internal.expressions.CountExpression@fc8b68b6
>> Any help would be appreciated.
>> Thanks,
>> Rahul
*new* Common Navigator Framework section in:
3.4RC4 Platform Plugin Developer Guide (Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Platform UI Committer for Common Navigator
http://wiki.eclipse.org/index.php/Common_Navigator_Framework
http://help.eclipse.org/galileo/topic/org.eclipse.platform.d oc.isv/guide/cnf.htm
FUDForum. Page generated in 0.03024 seconds
