Home » Eclipse Projects » Eclipse Platform » My plugin causes the workspace prompt to not appear
My plugin causes the workspace prompt to not appear [message #332937] Fri, 14 November 2008 11:51 Go to next message
The eclipse plugin that I wrote is causing a strange bug. The workspace
prompt doesn't appear on start up when my plugin is installed (no matter
what the setting for the prompt behavior is), and Eclipse opens with the
workspace as eclipse/workspace. It doesn't happen in all cases, and I
haven't yet figured out what the difference is between working and
non-working eclipse installs. I'm completely stumped and I could really
use some help. If anyone can point me in the right direction, I'd be very
grateful.
Justin
Re: My plugin causes the workspace prompt to not appear [message #332961 is a reply to message #332937] Mon, 17 November 2008 07:11 Go to previous messageGo to next message
Hi Justin,
I think this is not related to your plugin.
Be sure you checked the prompt for workspace preference in Preferences ->
General -> Start Up and Shutdown for all your eclipse installations.
Manu
Re: My plugin causes the workspace prompt to not appear [message #332962 is a reply to message #332937] Mon, 17 November 2008 07:45 Go to previous messageGo to next message
Justin,
One more thing about that is that the Prompt For Workspace preferences is
not stored at workspace level (of course, it's needed before any workspace
"exists") but at Eclipse installation's configuration level here
Eclipse4.5/eclipse/configuration/.settings/org.eclipse.ui.id e.prefs
Depending on your configuration this file could be also located in your
home directory.
Manu
Re: My plugin causes the workspace prompt to not appear [message #332965 is a reply to message #332962] Mon, 17 November 2008 09:35 Go to previous messageGo to next message
The first thing I checked was the preference, and it's not the problem.
When user's have both my plugin and WTP installed, the prompt doesn't
appear, no matter what the setting is.
Re: My plugin causes the workspace prompt to not appear [message #332978 is a reply to message #332965] Mon, 17 November 2008 13:09 Go to previous messageGo to next message
One more thing that I've found is that when you launch with the -clean
option, you are prompted for the workspace. When you run again without
-clean, there is no prompt.
Re: My plugin causes the workspace prompt to not appear [message #332981 is a reply to message #332978] Mon, 17 November 2008 16:04 Go to previous messageGo to next message
Ok. I think I've got it somewhat figured out. Something in the start
method of my plugin activator references the Resources plugin. When the
resources plugin initializes, it calls Platform.getInstanceLocation().
Since the instance location isn't set, it's setting it to the default
value, which causes the workspace prompt to not appear.
Why would my plugin activator's start method be called before the user has
even been prompted for the workspace?
Re: My plugin causes the workspace prompt to not appear [message #332983 is a reply to message #332981] Mon, 17 November 2008 17:07 Go to previous messageGo to next message
Upon further inspection, the reference to the Resources plugin doesn't
seem to be the problem, because the issue still occurs when I remove those
references to it.
Here's all I can narrow it down to:
in IDEApplication.checkInstanceLocation, instanceLoc.isSet() is returning
false when I run with -clean, and true when I don't. I haven't been able
to figure out why by stepping through in the debugger because it goes into
code in ServiceTracker that is pretty complicated. I'm not sure why the
location returned by InternalPlatform.getInstanceLocation is different
because of the presence of my plugin.
Re: My plugin causes the workspace prompt to not appear [message #332985 is a reply to message #332981] Tue, 18 November 2008 03:08 Go to previous messageGo to next message
"Justin Weir" <jweir66@hotmail.com> wrote in message
news:e5332de814a430c235540cc0638f7258$1@www.eclipse.org...
What extension points are you extending, and what plugins do you depend on?
Re: My plugin causes the workspace prompt to not appear [message #332991 is a reply to message #332985] Tue, 18 November 2008 09:56 Go to previous messageGo to next message
Plugin dependencies:
org.eclipse.core.runtime
org.eclipse.core.resources
org.eclipse.draw2d
org.eclipse.help
org.eclipse.help.appserver
org.eclipse.help.base
org.eclipse.help.ui
org.eclipse.help.webapp
org.eclipse.jdt.core
org.eclipse.jface
org.eclipse.text
org.eclipse.ui
org.eclipse.ui.console
org.eclipse.ui.editors
org.eclipse.ui.forms
org.eclipse.ui.ide
org.eclipse.wst.common.project.facet.core(optional)
org.eclipse.wst.common.modulecore(optional)
Extensions:
org.eclipse.core.resources.markers
org.eclipse.core.runtime.applications
org.eclipse.core.runtime.preferences
org.eclipse.core.runtime.products
org.eclipse.help.toc
org.eclipse.ui.actionSets
org.eclipse.ui.newWizards
org.eclipse.ui.perspectives
org.eclipse.ui.popupMenus
org.eclipse.ui.preferencePages
org.eclipse.ui.viewActions
org.eclipse.ui.views
Re: My plugin causes the workspace prompt to not appear [message #332995 is a reply to message #332991] Tue, 18 November 2008 14:06 Go to previous message
I found a line of code that I can remove to make the problem go away. Why
would a call like this:
MyDependencyPlugin.getDefault().getPreferenceStore().setValu e(foo)
in MyMainPlugin.start() cause this behavior? The call seems pretty benign
to me, but it has the side effect of causing some preferences-related
bundle to spool up and set the instance location to some default value.
Should I file a bug report?
Previous Topic:Getting launch configuration from TextConsole
Next Topic:remove entries from navigation history
Current Time: Sun Nov 23 23:34:26 EST 2025
Powered by FUDForum. Page generated in 0.08398 seconds
