Re: Switch Workspace working [message #332748 is a reply to message #332737] |
Fri, 07 November 2008 13:55 |
On 11/7/2008 12:57 AM, Sheela wrote:
> I am using eclipse 3.4 for my IDE.
> There is an option called "Switch Worksapce" in the "File" menubar , in
> which if we give the path of any workspace ,it closes the previous
> workspace and opens the new workspace.
> But if we give the path of same workspace which is already opened it
> stills closes that workspace and reopens the same workspace.
> Is this really required if the previous workspace and new workspace is
> same ?
> Before closing and reopening , it should first check if the new
> workspace is same as already opened workspace , if not same , then only
> close and open the workspace.
> Please look into this.
If you think something is a bug or can be improved, you need to enter it
into Bugzilla: https://bugs.eclipse.org/bugs
Eric
FUDForum. Page generated in 0.04842 seconds
