Home » Eclipse Projects » Eclipse Platform » [Fwd: refactoring framework and EMF2DOMSSE]
[Fwd: refactoring framework and EMF2DOMSSE] [message #332700] Wed, 05 November 2008 21:00 Go to next message
Originally posted by: anton.kraev.net
--------------010909070608040509060009
Forwarding to platform, because refactoring belongs here
Content-Type: message/rfc822;
name="refactoring framework and EMF2DOMSSE.eml"
Content-Disposition: inline;
filename="refactoring framework and EMF2DOMSSE.eml"
Path: build.eclipse.org!not-for-mail
Newsgroups: eclipse.webtools
Subject: refactoring framework and EMF2DOMSSE
Date: Wed, 05 Nov 2008 15:57:54 -0500
Organization: EclipseCorner
Message-ID: <get1cg$9mr$1@build.eclipse.org>
NNTP-Posting-Host: cpe001e378a57d6-cm001ceab606b2.cpe.net.cable.rogers.com
Mime-Version: 1.0
X-Trace: build.eclipse.org 1225918672 9947 72.138.245.248 (5 Nov 2008 20:57:52 GMT)
X-Complaints-To: news@build.eclipse.org
NNTP-Posting-Date: Wed, 5 Nov 2008 20:57:52 +0000 (UTC)
User-Agent: Thunderbird 2.0.0.17 (Windows/20080914)
Xref: build.eclipse.org eclipse.webtools:17692
As a result of refactoring, DocumentChange instance is created. It then
gets executed (changing corresponding IDocument). Refactored source
happens to be open by EMF2DOMSSE-based editor. EMF2DOMSSE receives
notification of change from command stack. This leads to editor being dirty.
The question is, how to get event from refactoring framework that
refactoring change is committed? DocumentChange.commit is empty. I could
override this method to manually notify open editors (if any), but I am
trying to avoid this dependency (refactoring plugin must depend on
editor plugin to notify it).
Any ideas?
Thanks for reading this!
--------------010909070608040509060009--
Re: [Fwd: refactoring framework and EMF2DOMSSE] [message #332721 is a reply to message #332700] Thu, 06 November 2008 15:30 Go to previous message
Ok, reply to myself. Use TextFileChange instead of DocumentChange, that
will save actual file, that can later be picked up by
IResourceChangeListener
> Subject:
> From:
> Anton Kraev <anton@kraev.net>
> Date:
> Newsgroups:
> eclipse.webtools
> dirty.
> Any ideas?
Previous Topic:Multiline TreeViewer
Next Topic:Replacing the splash image (via an update)
Current Time: Tue Nov 12 04:49:13 GMT 2024
Powered by FUDForum. Page generated in 0.03052 seconds
