Home » Eclipse Projects » Eclipse Platform » [p2] Works... the second time
[p2] Works... the second time [message #332693] Wed, 05 November 2008 11:53
Dimitrios Kolovos is currently offline Dimitrios KolovosFriend
I'm encountering some strange behaviour in p2 (using the 3.4.1 Modeling
distribution). For some update sites (but strangely enough not for all)
the following happens:
- I add an update site
- I select the check box next to it
- I press install
- The "Calculating requirements and dependencies" windows pops up
- It takes quite some time to fill the progress bar
- While the progress bar is being filled the check-boxes next to the
features of the update site are unticked (!!!)
- The Install window pops up with nothing in the list so I have to press
cancel
- I re-select the features under the update site, press install again
and then it works
(For example this happens with
http://download.eclipse.org/modeling/gmt/epsilon/updates/).
Anyone seen this before? Any idea what I may be doing wrong?
Dimtiris
Previous Topic:Override Open Action in Resource Navigator
Next Topic:[p2]Using links file in Eclipse 3.4
Current Time: Thu Dec 26 12:16:13 GMT 2024
Powered by FUDForum. Page generated in 0.02782 seconds
