Re: [p2]Using links file in Eclipse 3.4 [message #332694 is a reply to message #332669] |
Wed, 05 November 2008 14:01 |
If you don't get good response here, try posting to the
eclipse.technology.equinox group.
On 11/4/2008 10:01 AM, Kiran Kumar wrote:
> I am trying to add a feature to Eclipse 3.4 using links mechanism.
> The folder I am trying to add is having a feature with two different
> versions. Similarly the plug-ins folder also has two sets of same
> plug-ins with different versions corresponding to the two features (same
> feature of two different versions).
> On starting Eclipse 3.4, with a link file in links folder pointing to
> the above mentioned setup, latest version of the feature is getting
> loaded, but some of the plug-ins of older version are getting loaded.
> The set of plug-ins getting loaded with older version is not consistent
> every time I restart eclipse with clean option.
> The same setup works fine with older version of Eclipse.
> Is the setup mentioned above a valid one in Eclipse 3.4? Can I
> explicitly specify Eclipse to load a certain version of plug-ins?
FUDForum. Page generated in 0.03514 seconds
