How to execute an external program from a plugin [message #332602] |
Thu, 30 October 2008 15:47 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: mam05eux.studserv.uni-leipzig.de
i´ve built a plugin that calls an external c#-Program to import some
things using the .Net-Framework.
Ok, during the development of the plugin everything works fine (The
program "*.exe" lies in a subfolder named "temp" of the project) because
the plugin is loaded from the project, so it has a real filepath which I
get using the getInstallUri-Method.
Now my problem: When I export the plugin as a jar the exe cannot be
launched because the file lies within the jar.
So is there any possibility to execute the program at this location or
if not, how can i export a plugin as a directory so that eclipse is able
to load the plugin like a jar (I just tried to extract the contents of
the exportet jar and add the directory to the eclipse-plugin folder but
as I´ve expected eclipse didn´t load the plugin).
Thanks for the moment!
Re: How to execute an external program from a plugin [message #332613 is a reply to message #332609] |
Fri, 31 October 2008 14:55 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Andrew Niefer![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=aniefer%40gmail.com) Messages: 990 Registered: July 2009 |
Each bundle gets its own cache space. It should be cleaned up if the
bundle gets uninstalled, but otherwise I think it stays unless someone
runs with -clean.
In a headless build the shape of the built plugin depends on what the
containing feature says for the "unpack" attribute on the plug-in entry.
If not specified, the default is "true", which results in a folder.
If you are running productBuild.xml with a .product, and the container
feature is generated for you, then we guess, which is based on whether
or not the Bundle-Classpath has a '.' on it.
-Andrew
Remy Chi Jian Suen wrote:
> Andrew Niefer wrote:
>> FileLocator#find(Bundle bundle, IPath path, Map override)
>> will return a URL for the entry in your bundle.
>> Then
>> FileLocator.toFileURL(URL)
>> will extract the entry to a cache (normally under the
>> configuration/org.eclipse.osgi directory) and return the URL to the
>> location on disk.
> Andrew, how long is this cache alive for? Will the file be deleted
> automagically or...?
> >> able to load the plugin like a jar (I just tried to extract the
> >> contents of the exportet jar and add the directory to the
> >> eclipse-plugin folder but as I´ve expected eclipse didn´t load the
> >> plugin).
> There should be a way to export as a directory through the regular
> export wizard, I've done it before (and continue to do it on occasions
> when I need to update my application). I'm not sure how to do it through
> pdebuild though.
> Rem
Re: How to execute an external program from a plugin [message #332704 is a reply to message #332613] |
Thu, 06 November 2008 09:04 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Thanks for your replies.
I´m sorry that I wasn´t able to answer earlier but there was too much to
do at other projects.
So this tip worked fine, thanks a lot!
Stanley
> runs with -clean.
> -Andrew
>>> Then
>>> location on disk.
>> >> plugin).
>> through pdebuild though.
>> Rem
FUDForum. Page generated in 0.03335 seconds
