Home » Eclipse Projects » Eclipse Platform » Where to specify the name of the compiled *.war file?
Where to specify the name of the compiled *.war file? [message #332560] Tue, 28 October 2008 19:50
Originally posted by: markmccloud200.email.com
I duplicated an existing web service project,then renamed the new project
and changed some code in the web service implementation.
When I compile now the second web service then the result will be a file aaaa.war which
is successfully deployed to the app server.
This name however is the same as for the first web service. I thought the name of the project
determines the name of the *.war file. This is not the case as I had to notice.
If I for example list the services for the server on the "server" tab then two times
"aaaa" are shown.
On the other side I found no entry field in the project properties to
change the name of the final *.war file.
How can I change this into e.g. bbbb.war?
Mark
Previous Topic:Re: Menu item accel key works only after menu item has been shown
Next Topic:Information on self hosting.
Current Time: Wed Feb 05 04:54:03 GMT 2025
Powered by FUDForum. Page generated in 0.05545 seconds
