Re: Plugin properties from external plugins [message #332539 is a reply to message #332538] |
Mon, 27 October 2008 16:38 |
Ed Merks Messages: 33236 Registered: July 2009 |
Markus,
I don't think so. This tends to lead to some duplication. :-(
Markus Schindler wrote:
> Hi there,
> is it possible, to use plugin properties from a other plugin?
> For example: If you use the function "Externalize Strings", a
> plugin.properties file will be created in the root folder of the
> plugin. Is there a possibility to move this file to a other plugin?
> bin.includes = plugin.xml,\
> META-INF/,\
> icons/,\
> plugin.properties -> maybe plugin.xyz\plugin.properties
> regards,
> Markus
Ed Merks
FUDForum. Page generated in 0.03618 seconds
