| Home » Eclipse Projects » Eclipse Platform » Unable to create editor input
 Goto Forum:|
| Unable to create editor input [message #332526] | Sun, 26 October 2008 22:24  |  |
| Eclipse User  |  |  |  |  | Hi,
 I've an editor (Editor1) in my RCP app which has a button and when user
 clicks on that button in Editor1, I'm trying to open another editor
 (Editor2). However, when I try to instantiate editor2 I always get this
 exception: com.sun.jdi.InvocationException occurred invoking method.
 Editor2 is my class and it exists in the same package as editor1. It seems
 like the classloader could not find this class (Editor2). Does anyone know
 why this is happening? Below is my code:
 IWorkbenchPage page = getEditorSite().getWorkbenchWindow().getActivePage();
 Editor2Input editorInput2 = new Editor2Input(); // I could not instantiate
 this class even though this class is in my project in the same package as
 this code is
 try {
 page.openEditor(editorInput2, Editor2.ID);
 catch (PartInitException e) {
 e.printStackTrace();
 Thanks in advance,
 - Raja.
| Re: Unable to create editor input [message #332528 is a reply to message #332526] | Mon, 27 October 2008 06:34   |  |
| Eclipse User  |  |  |  |  | Raja,
 The problem could be as simple as not exporting all the packages of the
 plugin.  If you open the MANIFEST.MF, go to the Runtime tab, and use
 "Add..." to export more pages, does it suggest any?  Generally showing a
 full stack trace helps with details you might have omitted.  For
 example, sometimes the class might be found, but static initialization
 for it fails...
 Raja Kannappan wrote:
 > this code is
 > try {
 > Thanks in advance,
 > - Raja.
| Re: Unable to create editor input [message #332556 is a reply to message #332528] | Tue, 28 October 2008 12:39   |  |
| Eclipse User  |  |  |  |  | In this case, both Editor1 and Editor2 reside in the same packge under my source folder, but still when I try to instantiate Editor2Input class (which
 is in the same package also) I get this exception:
 com.sun.jdi.ClassNotLoadedException: Type has not been loaded occurred
 invoking method.
 Not sure why this is class not loaded while running my RCP app. Any ideas?
 - Raja.
 "Ed Merks" <Ed.Merks@gmail.com> wrote in message
 news:ge45f2$as6$2@build.eclipse.org...
 > Raja,
 > full stack trace helps with details you might have omitted.  For example,
 > sometimes the class might be found, but static initialization for it
 > fails...
 >> seems like the classloader could not find this class (Editor2). Does
 >> anyone know why this is happening? Below is my code:
 >> instantiate this class even though this class is in my project in the
 >> same package as this code is
 >> try {
 >> Thanks in advance,
 >> - Raja.
| Re: Unable to create editor input [message #332557 is a reply to message #332556] | Tue, 28 October 2008 12:55   |  |
| Eclipse User  |  |  |  |  | This is a multi-part message in MIME format. --------------080309010808010804060405
 Raja,
 Maybe you misspelled it in the plugin.xml?  The fact that it's not a
 class not found exception makes me think there's something going on
 you've not mentioned.  I.e., that something is failing during the
 initialization of the class.  Have you tried to step through this in the
 debugger?
 > invoking method.
 > - Raja.
 >> Raja,
 >> fails...
 >>> Hi,
 >>> try {
 >>> Thanks in advance,
 >>> - Raja.
 <html>
 <head>
 </head>
 Raja,<br>
 <br>
 the debugger?<br>
 <br>
 <br>
 <blockquote cite="mid:ge7f8l$hru$1@build.eclipse.org" type="cite">
 <pre wrap="">In this case, both Editor1 and Editor2 reside in the same packge under my
 invoking method.
 - Raja.
 "Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:Ed.Merks@gmail.com"><Ed.Merks@gmail.com></a> wrote in message
 <a class="moz-txt-link-freetext" href="news:ge45f2$as6$2@build.eclipse.org">news:ge45f2$as6$2@build.eclipse.org</a>...
 </pre>
 <blockquote type="cite">
 <pre wrap="">Raja,
 fails...
 </pre>
 <pre wrap="">Hi,
 try {
 Thanks in advance,
 - Raja.
 </pre>
 </blockquote>
 </blockquote>
 <pre wrap=""><!---->
 </pre>
 </blockquote>
 </body>
 </html>
 --------------080309010808010804060405--
 Current Time: Fri Oct 31 19:31:37 EDT 2025
 Powered by FUDForum . Page generated in 0.06403 seconds |
