Home » Eclipse Projects » Eclipse Platform » Refresh Coolbar after creating new AbstractContributionFactory.
Refresh Coolbar after creating new AbstractContributionFactory. [message #332501] Thu, 23 October 2008 17:59 Go to next message
kevin miles is currently offline kevin milesFriend
I'm looking for the best method of forcing the coolbar to update/refresh
to include my newly added AbstractContributionFactory's contributions.
right now i'm doing this and it feels hacky:
coolBarManager.removeAll();
menuService.populateContributionManager(
coolBarManager,
MenuUtil.MAIN_TOOLBAR );
Re: Refresh Coolbar after creating new AbstractContributionFactory. [message #332519 is a reply to message #332501] Fri, 24 October 2008 19:23 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
> coolBarManager,
Gack! I nearly dropped my coffee :-) That will only cause sadness,
unfortunately.
Having an programmatic ACF added to existing ContributionManagers that
were populated isn't supported until 3.4.
I'm not sure how to tackle that in 3.3
PW
Paul Webster
Re: Refresh Coolbar after creating new AbstractContributionFactory. [message #332562 is a reply to message #332519] Tue, 28 October 2008 20:31 Go to previous messageGo to next message
once i stopped laughing i began to fret about my current approach...
i'll let you know what i find.
kjm
>> update/refresh to include my newly added AbstractContributionFactory's
>> contributions.
>> coolBarManager,
> unfortunately.
> PW
Re: Refresh Coolbar after creating new AbstractContributionFactory. [message #332574 is a reply to message #332562] Wed, 29 October 2008 13:34 Go to previous message
In 3.4 we keep a list of ManagerPopulationRecords, so when another ACF
is added
org.eclipse.ui.internal.menus.WorkbenchMenuService.addContri butionFactory(AbstractContributionFactory)
knows to "install" it immediately.
In 3.3 you would somehow have to take your ACF and call into
org.eclipse.ui.internal.menus.WorkbenchMenuService.processAd ditions(IServiceLocator,
Expression, ContributionManager, AbstractContributionFactory, Set) to
get it added in a "timely" manner, but that's a private method (the best
you can do in 3.3 is via reflection).
The other (totally non-portable and wacky) suggestion would be to run
some similar code from within that method, you need a ContributionRoot
and then you could fill it in yourself (having already "illegally"
obtained the CoolBarManager :-)
PW
Paul Webster
Previous Topic:Forcing repartition of document in text editor
Next Topic:Unable to create editor input
Current Time: Thu Jan 02 20:07:55 GMT 2025
Powered by FUDForum. Page generated in 0.03442 seconds
