Home » Eclipse Projects » Eclipse Platform » Databinding - DirtyState of an BindingContext
Databinding - DirtyState of an BindingContext [message #332486] |
Wed, 22 October 2008 11:03  |
I just try to develop an editor based on JFace-Databinding. For this I
need to know if an Binding is dirty or not (DirtyState), to save my
Editor, if changes are detected.
But I do not know where to get this(DirtyState) information.
I found a Bug (ID 119791). Is there a workaround on that or is ist still
not working ?
Maybe Andrey Tarantsov can tell me more about it ?
Andreas
Re: Databinding - DirtyState of an BindingContext [message #332489 is a reply to message #332488] |
Wed, 22 October 2008 14:03   |
--------------010007060507010300040004
Boris,
Of course if he were using EMF's data binding integration that you
mostly wrote, the updates would use EMF.Edit's command stack and not
only would that provide dirty state tracking, but it would also support
undo...
Boris Bokowski wrote:
> My guess would be that you need something outside of the data binding
> framework (think about Undo/Redo) but for now, if you would like to know if
> there have been any changes in the UI at all, you could have a look at the
> logic in WizardPageSupport and how it hooks generic change listeners on all
> target observables in a data binding context.
> As for the bug, it hasn't been updated (with technical discussion) in over a
> year, so I wouldn't hold my breath.
> Boris
> "Andreas Schmid" <aschmid@vetinf.de> wrote in message
> news:gdnfck$2on$1@build.eclipse.org...
>> Hello,
>> not working ?
>> Thanks
>> Andreas
<html>
<head>
</head>
Boris,<br>
<br>
undo...<br>
<br>
<br>
<blockquote cite="mid:gdnod4$7u6$1@build.eclipse.org" type="cite">
<pre wrap="">My guess would be that you need something outside of the data binding
Boris
"Andreas Schmid" <a class="moz-txt-link-rfc2396E" href="mailto:aschmid@vetinf.de"><aschmid@vetinf.de></a> wrote in message
<a class="moz-txt-link-freetext" href="news:gdnfck$2on$1@build.eclipse.org">news:gdnfck$2on$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hello,
not working ?
Andreas
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------010007060507010300040004--
Re: Databinding - DirtyState of an BindingContext [message #332493 is a reply to message #332489] |
Thu, 23 October 2008 02:31   |
At current, we have registered a Convertor in our UpdatePolicy, to
convert a String , given in a TextBox, to an Boolean ("true" => true,
everything else => false) and vice versa.
But the Observers only provide the "real" value, which means the
unconverted String from the textbox. The Binding, the binding context
nor the events provide the converted value. Is there any other place to
look for the converted value, during an ValueChanged or an ListChanged
event ?
Andreas
Ed Merks schrieb:
> Boris,
> undo...
>> Boris
>>> Hello,
>>> not working ?
>>> Thanks
>>> Andreas
Re: Databinding - DirtyState of an BindingContext [message #332499 is a reply to message #332493] |
Thu, 23 October 2008 11:25  |
When I want easy access to the converted value, I usually chain two
bindings, with a shared observable in the middle:
Text text = ...
IObservableValue target = SWTObservables.observeText(text, SWT.Modify);
IObservableValue convertedTarget = new WritableValue();
Bean bean = ...
IObservableValue value = BeansObservables.observeValue(bean, "value");
dbc.bindValue(convertedTarget, value, null, null);
dbc.bindValue(target, convertedTarget, targetToModelStrategy,
modelToTargetStrategy);
Matthew
> event ?
> Andreas
> Ed Merks schrieb:
>> Boris,
>> support undo...
>>> know if there have been any changes in the UI at all, you could have
>>> a look at the logic in WizardPageSupport and how it hooks generic
>>> change listeners on all target observables in a data binding context.
>>> over a year, so I wouldn't hold my breath.
>>> Boris
>>>> Hello,
>>>> I need to know if an Binding is dirty or not (DirtyState), to save
>>>> my Editor, if changes are detected.
>>>> still not working ?
>>>> Thanks
>>>> Andreas
Current Time: Thu Mar 13 16:03:42 EDT 2025
Powered by FUDForum. Page generated in 0.04485 seconds
