Home » Eclipse Projects » Eclipse Platform » Updates and restoreState
Updates and restoreState [message #332481] Wed, 22 October 2008 10:00 Go to next message
Markus Schindler is currently offline Markus SchindlerFriend
Member
we develope a rcp application and setting setSaveAndRestore true. Now we
got following problem:
We manually update our plugins via the
org.eclipse.update.standalone.ScriptedCommands (Install, Uninstall, etc.),
after that, it's possible that a view has been deleted or a new view was
added to a perspective.
But when the user restart the application, eclipse tries to load the old
saved perspective, so the changes won't appear.
Is there a programmatically way to reset the workbench, afer updating?
regards
Markus
Re: Updates and restoreState [message #332482 is a reply to message #332481] Wed, 22 October 2008 11:38 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
You can call org.eclipse.ui.IWorkbenchPage.resetPerspective()
PW
Paul Webster
Previous Topic:how to terminate an ILaunch (or IProcess) programmatically
Next Topic:Handle ESC press to a whole shell as ENTER is handled with setDefaultButton
Current Time: Sat Dec 21 16:39:04 GMT 2024
Powered by FUDForum. Page generated in 0.03239 seconds
