[swt][cocoa] Cannot run an Eclipse application with the SWT Cocoa port [message #332420] |
Tue, 21 October 2008 10:51 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: atoulme.intalio.com
I'd like to test the current state of the SWT Cocoa port.
Here is what I did:
I checked out the sources of org.eclipse.swt and org.eclipse.swt.coca.macosx
I renamed the cocoa classpath file to be the .classpath file.
I built those plugins.
Then I tried to start my eclipse instance, and I had this exception:
!ENTRY org.eclipse.osgi 4 0 2008-10-21 12:23:01.185
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError: no swt-cocoa-3513 or swt-cocoa in
swt.library.path, java.library.path or the jar file
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:23 5)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:15 3)
at org.eclipse.swt.internal.C.<clinit>(C.java:21)
at org.eclipse.swt.internal.cocoa.id.objc_getClass(id.java:35)
at org.eclipse.swt.internal.cocoa.NSObject.alloc(NSObject.java: 28)
at org.eclipse.swt.graphics.Device.<init>(Device.java:116)
at org.eclipse.swt.widgets.Display.<init>(Display.java:542)
at org.eclipse.swt.widgets.Display.<init>(Display.java:533)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:525)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:161)
org.eclipse.ui.internal.ide.application.IDEApplication.creat eDisplay(IDEApplication.java:143)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:88)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
What can I do about this ? Is there an error on my end ?
Antoine
Re: [swt][cocoa] Cannot run an Eclipse application with the SWT Cocoa port [message #332425 is a reply to message #332420] |
Tue, 21 October 2008 14:14 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Sorry, should have posted to the swt newsgroup.
Antoine
Antoine Toulme wrote:
> Here is what I did:
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Antoine
Re: [swt][cocoa] Cannot run an Eclipse application with the SWT Cocoa port [message #332431 is a reply to message #332427] |
Tue, 21 October 2008 16:21 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I updated, rebuilt, restarted, same error.
The contents of the cocoa fragment :
about_files
META-INF
..project
about.html
build.properties
build.xml
fragment.properties
libswt-awt-cocoa-3513.jnilib
libswt-cocoa-3513.jnilib
libswt-pi-cocoa-3513.jnilib
libswt-xulrunner-cocoa-3513.jnilib
I'm pretty sure this has more to do with running the Cocoa port in an
Eclipse instance.
Can you run an Eclipse instance with the cocoa port, or just your samples ?
Antoine
Duong Nguyen wrote:
> Hi Antoine,
> You may have checked out from HEAD while we were in the middle of an
> integration build yesterday evening. Do you see the libraries with the
> correct version (3513) in the org.eclipse.swt.coca.macosx fragment?
> I just checked out from HEAD this morning and I was able to launch my
> examples. Can you update and try it again?
> Duong
Re: [swt][cocoa] Cannot run an Eclipse application with the SWT Cocoa port [message #332447 is a reply to message #332439] |
Tue, 21 October 2008 19:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
OK, it worked! Awesome, thanks!
Antoine
>> Eclipse instance.
>> samples ?
> I'm running with a recent cocoa build and I can run another Eclipse
> instance (self host). What version of Eclipse are you using? Is your
> host Eclipse environment carbon? If yes, you'll need to change the
> target platform environment variable to cocoa.
> STEPS:
> - open the Preferences page - select Preferences from the Window menu
> - select Plug-in Development->Target Platform
> - select Environment tab
> - if the Window System isn't cocoa, change it to cocoa
> - press Apply and close the preferences dialog
> As an alternative, you can download the latest cocoa build of Eclipse
> and run it.
FUDForum. Page generated in 0.04230 seconds
