[swt][cocoa] Cannot run an Eclipse application with the SWT Cocoa port [message #332420] |
Tue, 21 October 2008 06:51  |
Originally posted by: atoulme.intalio.com
I'd like to test the current state of the SWT Cocoa port.
Here is what I did:
I checked out the sources of org.eclipse.swt and org.eclipse.swt.coca.macosx
I renamed the cocoa classpath file to be the .classpath file.
I built those plugins.
Then I tried to start my eclipse instance, and I had this exception:
!ENTRY org.eclipse.osgi 4 0 2008-10-21 12:23:01.185
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError: no swt-cocoa-3513 or swt-cocoa in
swt.library.path, java.library.path or the jar file
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:23 5)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:15 3)
at org.eclipse.swt.internal.C.<clinit>(C.java:21)
at org.eclipse.swt.internal.cocoa.id.objc_getClass(id.java:35)
at org.eclipse.swt.internal.cocoa.NSObject.alloc(NSObject.java: 28)
at org.eclipse.swt.graphics.Device.<init>(Device.java:116)
at org.eclipse.swt.widgets.Display.<init>(Display.java:542)
at org.eclipse.swt.widgets.Display.<init>(Display.java:533)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:525)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:161)
org.eclipse.ui.internal.ide.application.IDEApplication.creat eDisplay(IDEApplication.java:143)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:88)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
What can I do about this ? Is there an error on my end ?
Antoine
Re: [swt][cocoa] Cannot run an Eclipse application with the SWT Cocoa port [message #332447 is a reply to message #332439] |
Tue, 21 October 2008 15:24  |
OK, it worked! Awesome, thanks!
Antoine
Duong Nguyen wrote:
>> I'm pretty sure this has more to do with running the Cocoa port in an
>> Eclipse instance.
>> Can you run an Eclipse instance with the cocoa port, or just your
>> samples ?
> I'm running with a recent cocoa build and I can run another Eclipse
> instance (self host). What version of Eclipse are you using? Is your
> host Eclipse environment carbon? If yes, you'll need to change the
> target platform environment variable to cocoa.
> STEPS:
> - open the Preferences page - select Preferences from the Window menu
> - select Plug-in Development->Target Platform
> - select Environment tab
> - if the Window System isn't cocoa, change it to cocoa
> - press Apply and close the preferences dialog
> As an alternative, you can download the latest cocoa build of Eclipse
> and run it.
FUDForum. Page generated in 0.04151 seconds
