Home » Eclipse Projects » Eclipse Platform » No Handler error
No Handler error [message #332325] Sun, 19 October 2008 08:25 Go to next message
Kamesh Sampath is currently offline Kamesh SampathFriend
Hi ,
I am working on a cheat sheet , in one of the steps in cheatsheet i want the
user to checkout the code from CVS/Subversion. I had added the command
"addLocation" of the CVS. When I execute the command it fails saying " No
Handler Error" , but when I change from my existing perspective to CVS
Perspective , then execute it it works well .But in real time that will not
be the scenario, I want the user to make use of the cheatsheet in any
prespective he is in . I did see an article in Dzone but could'nt understand
whats said there .
Can anyone help on how to aovid this issue ?
Thanks.
Kamesh
Re: No Handler error [message #332470 is a reply to message #332325] Tue, 21 October 2008 22:56 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
It sounds like that action is in an actionSet, and is not active in your
perspective. Is that the case?
PW
Paul Webster
Previous Topic:How to use / customize eclipse logger
Next Topic:Incorrect shortcut behaviour: show view: declaration
Current Time: Fri Nov 08 22:40:11 GMT 2024
Powered by FUDForum. Page generated in 0.02886 seconds
