Home » Eclipse Projects » Eclipse Platform » How to use / customize eclipse logger
How to use / customize eclipse logger [message #332290] Fri, 17 October 2008 04:50 Go to next message
How can I use the Eclipse 3.4 default logger in my plugins?
And is it possible to configure the logger? In my case I want the logger
to log to another directory.
Jan
Re: How to use / customize eclipse logger [message #332338 is a reply to message #332290] Mon, 20 October 2008 04:30 Go to previous messageGo to next message
anybody??
Re: How to use / customize eclipse logger [message #332468 is a reply to message #332290] Tue, 21 October 2008 18:55 Go to previous message
To use it, if you currently subclass core runtime Plugin you can use
org.eclipse.core.runtime.Plugin.getLog()
Also check out org.eclipse.ui.statushandlers.StatusManager which can
work with the core runtime log system through the use of status adapters.
You can read up on status handlers in the Help>Help Content>Platform
Plug-in Developer Guide
PW
Paul Webster
Previous Topic:Where is the menu "Generate Bindung Content" ?
Next Topic:No Handler error
Current Time: Thu Mar 13 15:56:51 EDT 2025
Powered by FUDForum. Page generated in 0.03795 seconds
