How to add an Annotation (visible in TextEditor and Childs) to a File? [message #332218] |
Sat, 11 October 2008 14:44 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Jarod McKnight![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=eclipse%40dareddevelopment.com) Messages: 2 Registered: July 2009 |
Junior Member |
I am building a plugin to show source duplications (clones in short) in
files with text content.
I already build my own Markers (#1) and added them to the IFiles having
some clones. I also added a decorator (#2), which marks all my files and
folders in Ressources views (like the Navigator) with an icon. That both
works, but I am unable to add Annotations to the source code.
As far as I understand, it should be possible to add Annotations which
will be displayed in every Editor extending the TextEditor (so that
someone editing an java file in the default java editor can see them, for
example). For my annotations I extended AnnotationType (#3) and
markerAnnotationSpecification (#4). In the preference page under
TextEditor->Annotations my new Annotation shows up, so it looks like I
made that correct.
But now I am stuck, because I haven't found (neither in the eclipse plugin
documentations, nor in the newsgroup [maybe I just lack search-fu this
weekend]) a way to add an Annotation to the File. What I found so far is,
that I need a AnnotationModel to add Annotations. My try to build a new
Model wasn't succesfull (#5), and I haven't found a method to obtain one
for the File.
I would appreciate any hint, so thx in advance
~ Jarod
#1:
<extension
id="duplicaty.clone.marker"
name="Clone Marker"
point="org.eclipse.core.resources.markers">
<super
type="org.eclipse.core.resources.textmarker">
</super>
</extension>
#2:
<extension
point="org.eclipse.ui.decorators">
<decorator
adaptable="true"
class="duplicaty.decorators.ContainsClone"
id="duplicaty.decorators.ContainsClone"
label="Contains Clone Decorator"
lightweight="true"
state="true">
<enablement>
<and>
<objectClass
name="org.eclipse.core.resources.IResource">
</objectClass>
<or>
<objectClass
name="org.eclipse.core.resources.IFolder">
</objectClass>
<objectClass
name="org.eclipse.core.resources.IFile">
</objectClass>
</or>
</and>
</enablement>
</decorator>
</extension>
#3:
<extension
point="org.eclipse.ui.editors.annotationTypes">
<type
markerSeverity="0"
markerType="duplicaty.clone.marker"
name="duplicaty.clone.annotation">
</type>
</extension>
#4:
<extension
point="org.eclipse.ui.editors.markerAnnotationSpecification ">
<specification
annotationType="duplicaty.clone.annotation"
colorPreferenceKey="Clone_Annotation"
colorPreferenceValue="125,125,0"
contributesToHeader="false"
highlightPreferenceKey="Clone"
highlightPreferenceValue="true"
includeOnPreferencePage="true"
isGoToNextNavigationTarget="false"
isGoToPreviousNavigationTarget="false"
label="Clone"
overviewRulerPreferenceKey="Clone_Annotation"
overviewRulerPreferenceValue="true"
showInNextPrevDropdownToolbarAction="false"
textPreferenceKey="Clone_Annotation"
textPreferenceValue="true"
textStylePreferenceValue="NONE"
verticalRulerPreferenceKey="Clone_Annotation"
verticalRulerPreferenceValue="true">
</specification>
</extension>
#5:
// sourceFile is of class File (from eclipse)
ResourceMarkerAnnotationModel model = new
ResourceMarkerAnnotationModel(sourceFile);
model.addAnnotation(new
Annotation("duplicaty.clone.annotation",false,"CLONE"), new
Position(20,5));
Re: How to add an Annotation (visible in TextEditor and Childs) to a File? [message #332228 is a reply to message #332218] |
Mon, 13 October 2008 12:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Dani Megert![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=Daniel_Megert%40ch.ibm.com) Messages: 3802 Registered: July 2009 |
Jarod McKnight wrote:
> in files with text content.
> having some clones. I also added a decorator (#2), which marks all my
> files and folders in Ressources views (like the Navigator) with an
> icon. That both works, but I am unable to add Annotations to the
> source code.
> for example). For my annotations I extended AnnotationType (#3) and
> made that correct.
> plugin documentations, nor in the newsgroup [maybe I just lack
> search-fu this weekend]) a way to add an Annotation to the File. What
> I found so far is, that I need a AnnotationModel to add Annotations.
> My try to build a new Model wasn't succesfull (#5), and I haven't
> found a method to obtain one for the File.
is not valid and textStylePreferenceKey is missing. Take a look at the
contributions in org.eclipse.ui.editors/plugin.xml for working examples.
Dani
> ~ Jarod
> #1:
> <extension
> name="Clone Marker"
> <super
> </super>
> </extension>
> #2:
> <extension
> <decorator
> adaptable="true"
> lightweight="true"
> state="true">
> <enablement>
> <and>
> <objectClass
> </objectClass>
> <or>
> <objectClass
> </objectClass>
> <objectClass
> </objectClass>
> </or>
> </and>
> </enablement>
> </decorator>
> </extension>
> #3:
> <extension
> <type
> markerSeverity="0"
> </type>
> </extension>
> #4:
> <extension
> <specification
> label="Clone"
> </specification>
> </extension>
> #5:
> Position(20,5));
FUDForum. Page generated in 0.02540 seconds
