Home » Eclipse Projects » Eclipse Platform » How to set and get a configuration file for a eclipse plugin
How to set and get a configuration file for a eclipse plugin [message #332217] Sat, 11 October 2008 05:22 Go to next message
I am developing a eclipse plug-in and have a configuration file which
contains the configuration information for the plug-in. These information
are not neccessary to be exposed to the plug-in user. So these information
are not preference. I would like to put the configuration file within the
plug-in such as the root folder of the plug-in jar or the .metadata area
of the plug-in. I am not sure which way is a better practice and how could
I retrieve the configuration file when plug-in is activated.
Highly appreciated for any suggestion!
hao
Re: How to set and get a configuration file for a eclipse plugin [message #332220 is a reply to message #332217] Sat, 11 October 2008 21:04 Go to previous messageGo to next message
"Hao " <d95776@yahoo.com> wrote in message
news:4c579dc9efae68d04f30666d971c8332$1@www.eclipse.org...
>plug-in such as the root folder of the plug-in jar or the .metadata area of
>the plug-in. I am not sure which way is a better practice and how could I
Try Platform.getStateLocation().
There are also a bunch of similar getXxxLocation() methods in Platform - you
might want to read the javadoc for all of them, to be sure you are thinking
about your problem correctly.
Re: How to set and get a configuration file for a eclipse plugin [message #332222 is a reply to message #332217] Sun, 12 October 2008 10:46 Go to previous messageGo to next message
> information are not neccessary to be exposed to the plug-in user. So
> these information are not preference. I would like to put the
> configuration file within the plug-in such as the root folder of the
> plug-in jar or the .metadata area of the plug-in. I am not sure which
> way is a better practice and how could I retrieve the configuration file
> hao
Hi Hao,
for delivering the initial plug-in configuration, i would prefer to put
the properties file into the plug-in root directory. Your activator may
access the ressource via getBundle().getResource("props_file_name").
If you want to provide the ability of load/save an plug-in internal
state, then use the suggestion of Walter.
Holger
Re: How to set and get a configuration file for a eclipse plugin [message #332304 is a reply to message #332222] Fri, 17 October 2008 11:31 Go to previous message
[for delivering the initial plug-in configuration, i would prefer to put
You are right. I like your idea.
thanks!
hao
Previous Topic:Testing and Workspace Deletion
Next Topic:How to list all (non-default) remote feature site currently added?
Current Time: Wed Apr 16 13:50:47 EDT 2025
Powered by FUDForum. Page generated in 0.03736 seconds
