Home » Eclipse Projects » Eclipse Platform » Delaying resource modifications to prevent "resource tree is locked" exception
Delaying resource modifications to prevent "resource tree is locked" exception [message #332195] Thu, 09 October 2008 11:27 Go to next message
Mikhail Kadan is currently offline Mikhail KadanFriend
Member
Hi.
I have my own implementation of IResourceChangeListener, which recognizes
when file was moved and then makes some modifications to i's content. But
when I try to save this modified content to file using IFile.setContent(),
i get the following exception:
org.eclipse.core.internal.resources.ResourceException: The resource tree
is locked for modifications.
org.eclipse.core.internal.resources.WorkManager.checkIn(Work Manager.java:115)
org.eclipse.core.internal.resources.Workspace.prepareOperati on(Workspace.java:1747)
at org.eclipse.core.internal.resources.File.setContents(File.ja va:364)
at org.eclipse.core.internal.resources.File.setContents(File.ja va:469)
I understand that I cannot modify file's content while processing resource
delta. So I need someway to delay this modifaction. Is there a standart
way to do this (maybe some queue, which accepts runnables, and then exutes
them in batch after processing whole resource delta and unlocking resource
tree) or I have to write my own implementation for this operation?
Thanks.
Re: Delaying resource modifications to prevent "resource tree is locked" exception [message #332197 is a reply to message #332195] Thu, 09 October 2008 12:49 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
You can either spawn a org.eclipse.core.resources.WorkspaceJob or use
LTK Refactoring and provide a MoveParticipant -
http://www.eclipse.org/articles/
Paul Webster
Previous Topic:Problem with BasicNewProjectResourceWizard
Next Topic:Mysteries in the Software Updates UI
Current Time: Thu Aug 29 12:40:04 GMT 2024
Powered by FUDForum. Page generated in 1.77080 seconds
