Home » Eclipse Projects » Eclipse Platform » Is there an event for generating getters/setters?
Is there an event for generating getters/setters? [message #332185] Wed, 08 October 2008 23:13
David M. Karr is currently offline David M. KarrFriend
I'm trying to get into the "EclipseMonkey" feature, now "Aptana
Scripting". part of this allows attaching listeners to events. The hard
part is knowing what objects can fire events that I can attach listeners
to. For instance, I'm trying to determine whether there's an event
specifically fired when the user generates code from the "Generate
Getters/Setters" dialog. Is this possible. Where would I find out about
this? I've already read all the EclipseMonkey documentation.
Previous Topic:Error after updating process
Next Topic:using command handlers to enable/disable push buttons
Current Time: Fri Oct 18 08:05:00 GMT 2024
Powered by FUDForum. Page generated in 0.02947 seconds
