Home » Eclipse Projects » Eclipse Platform » Changing Eclipse preferences programmatically
Changing Eclipse preferences programmatically [message #332168] Wed, 08 October 2008 06:28 Go to next message
Originally posted by: j4r0d.hotmail.com
I have tried the following code for changing the eclipse preferences; more
precisely the JDK compliance level and the contextual launch option.
I have placed the following code in the start method of my plugin Activator
class.
Preferences nodeCore = new DefaultScope().getNode("org.eclipse.jdt.core");
if (nodeCore != null) {
nodeCore.put("org.eclipse.jdt.core.compiler.source", "1.3");
nodeCore.put("org.eclipse.jdt.core.compiler.compliance", "1.3");
nodeCore.put("org.eclipse.jdt.core.compiler.problem.assertIdentifier ",
"ignore");
nodeCore.put("org.eclipse.jdt.core.compiler.problem.enumIdentifier ",
"ignore");
Preferences nodeUI = new DefaultScope().getNode("org.eclipse.debug.ui");
if (nodeUI != null)
nodeUI.putBoolean("org.eclipse.debug.ui.UseContextualLaunch ", false);
Then when I run Eclipse and I go to the preferences menu, unfortunately, I
can see that the compiler compliance level is still 6.0 and the contextual
launch option is still turned on.
Why is my code not working? What is the problem?
Thanks in advance for your help.
J.
Re: Changing Eclipse preferences programmatically [message #332174 is a reply to message #332168] Wed, 08 October 2008 08:25 Go to previous messageGo to next message
What if you use InstanceScope?
PW
Paul Webster
Re: Changing Eclipse preferences programmatically [message #332176 is a reply to message #332174] Wed, 08 October 2008 08:57 Go to previous message
Oh lord,
you saved my life ;-)
Thx!
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:gci985$pcv$4@build.eclipse.org...
> PW
> Paul Webster
Previous Topic:Adding plugins through natures?
Next Topic:Contributing command to popup submenu
Current Time: Mon Nov 03 21:32:33 EST 2025
Powered by FUDForum. Page generated in 0.50213 seconds
