Home » Archived » Visual Editor (VE) » File ..ROOT...override
File ..ROOT...override [message #33673] Thu, 29 April 2004 07:44 Go to next message
Originally posted by: th.huebner.sap.corp
In plugin org.eclipse.jem exists a file called ..ROOT...override.
Through the three dots in the filename it's inpossible to check
in this file into Perforce. In Perforce three dots are reserved for
wildcards.
Is it possible to rename such files? What is the reason for this
naming convention?
Best Regards,
Thomas
Re: File ..ROOT...override [message #33719 is a reply to message #33673] Thu, 29 April 2004 07:53 Go to previous messageGo to next message
The file ..ROOT...override also exists in plugin org.eclipse.ve.java.core.
"Thomas H
Re: File ..ROOT...override [message #33824 is a reply to message #33719] Thu, 29 April 2004 18:17 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
It's a special file, it is named that way so that it willbe unique and
not likely to collide with any other file that someone may place out there.
Thanks, Rich Kulp
Re: File ..ROOT...override [message #35744 is a reply to message #33824] Wed, 05 May 2004 14:28 Go to previous message
Will .ROOT.override cause a problem? If it doesn't, then please open a
bugzilla bug against VE JEM component to have them renamed to that.
Thanks, Rich Kulp
Re: File ..ROOT...override [message #587464 is a reply to message #33673] Thu, 29 April 2004 07:53 Go to previous message
"Thomas H
Re: File ..ROOT...override [message #587510 is a reply to message #33719] Thu, 29 April 2004 18:17 Go to previous message
Thanks, Rich Kulp
Re: File ..ROOT...override [message #588155 is a reply to message #33824] Wed, 05 May 2004 14:28 Go to previous message
Thanks, Rich Kulp
Previous Topic:How to set the layout of a pane?
Next Topic:SWT support?
Current Time: Wed Feb 05 06:54:43 GMT 2025
Powered by FUDForum. Page generated in 0.06399 seconds
