Re: Launching external executable? [message #333123 is a reply to message #332121] |
Wed, 26 November 2008 10:41 |
Originally posted by: luimarr1.upvnet.upv.es
Daniel Krügler escribió:
> Joachim Rietz wrote:
>> For a certain scenario I need to launch an external executable (*.exe)
>> from within an RCP application.
>> I also need to have control of the launched process, e.g. get return
>> status etc.
>> Which is the most suiteable and recommended approach for this?
>> I've searched a lot about launching and basically all I've found deals
>> with Eclipse launch framework (i.e. creating ILaunchConfigurationType,
>> ILaunchConfiguration...).
>> But isn't this approach more applicable for run/debug activities
>> during development?
>> Or if needed to provide run/debug launch configuration UI to user?
>> Because this is not the case for me. I just need to launch an
>> executable and have proper control for that launched process.
>> BTW. I'm running on Windows platform.
> I would have tried Runtime#exec. The return type is a Process object,
> which has e.g. a method waitFor and a method exitValue....
> HTH,
> Daniel Krügler
Hi Daniel,
i did it not long ago and found some trouble that finally solved
reading this article:
http://www.javaworld.com/javaworld/jw-12-2000/jw-1229-traps. html?page=3
regards,
Luis
FUDForum. Page generated in 0.03333 seconds
