Home » Eclipse Projects » Eclipse Platform » display whitespace toggle shortcut
display whitespace toggle shortcut [message #332059] Wed, 01 October 2008 20:09 Go to next message
Chad is currently offline ChadFriend
Is there a way to turn off/on the display of whitespace characters in
Eclipse using a keyboard shortcut?
I know I can do this via Windows, Preferences, General, Editors, Text
Editors, Show Whitespace Characters, but would like to be able to toggle
this setting via the keyboard.
Chad
Re: display whitespace toggle shortcut [message #332063 is a reply to message #332059] Wed, 01 October 2008 20:48 Go to previous messageGo to next message
The command is named "Show Whitespace Characters" so you should be able
to find it in the Key bindings preferences (General > Keys) and bind it
to the shortcut of your choice.
Hope this helps,
Eric
Re: display whitespace toggle shortcut [message #332084 is a reply to message #332059] Thu, 02 October 2008 12:31 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
And don't forget Quick Access :-)
CTRL+3 swc
PW
Paul Webster
Re: display whitespace toggle shortcut [message #332093 is a reply to message #332063] Thu, 02 October 2008 16:40 Go to previous messageGo to next message
Thanks, that's just what I needed.
Re: display whitespace toggle shortcut [message #332094 is a reply to message #332084] Thu, 02 October 2008 16:44 Go to previous message
I wasn't familiar with Quick Access. Very cool -- thanks for the tip!
Previous Topic:Custom install handler not getting run with Eclipse 3.4
Next Topic:Databinding throws NPE
Current Time: Sun Dec 22 05:58:51 GMT 2024
Powered by FUDForum. Page generated in 0.03411 seconds
