Re: JVM terminated. Exit code 13 [message #331961 is a reply to message #331957] |
Tue, 30 September 2008 16:11 |
Originally posted by: codeslave.ca.ibm.com
try `eclipse -vm /usr/java6_64/jre/bin/java -vmargs ...`
TsanChung wrote:
> I want to get a 64-bit eclipse prebuilt binary for AIX 5.3 on ppc.
> It seems that only 32-bit eclipse prebuilt binary for AIX is provided by
> eclipse.org.
> Therefore I build 64-bit eclipse binary from source R-3.3 as follows:
> export PATH=$PATH:/home/twong/apache-ant-1.7.1/bin
> export ANT_HOME=/home/twong/apache-ant-1.7.1
> export JAVA_HOME=/usr/java6_64
> sh build -os aix -ws motif -arch ppc
> The org.eclipse.sdk-I20070625-1500-aix.motif.ppc.zip file is built
> successfully at the result directory.
> I unzip the eclipse file to another directory but eclipse fail to start
> with the "JVM terminated. Exit code 13" error popup window.
> I tried these but both failed:
> eclipse
> eclipse -clean
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
FUDForum. Page generated in 0.04120 seconds
