Home » Eclipse Projects » Eclipse Platform » JVM terminated. Exit code 13
JVM terminated. Exit code 13 [message #331957] Tue, 30 September 2008 11:30 Go to next message
I want to get a 64-bit eclipse prebuilt binary for AIX 5.3 on ppc.
It seems that only 32-bit eclipse prebuilt binary for AIX is provided by
eclipse.org.
Therefore I build 64-bit eclipse binary from source R-3.3 as follows:
export PATH=$PATH:/home/twong/apache-ant-1.7.1/bin
export ANT_HOME=/home/twong/apache-ant-1.7.1
export JAVA_HOME=/usr/java6_64
sh build -os aix -ws motif -arch ppc
The org.eclipse.sdk-I20070625-1500-aix.motif.ppc.zip file is built
successfully at the result directory.
I unzip the eclipse file to another directory but eclipse fail to start
with the "JVM terminated. Exit code 13" error popup window.
I tried these but both failed:
eclipse
eclipse -clean
Re: JVM terminated. Exit code 13 [message #331961 is a reply to message #331957] Tue, 30 September 2008 12:11 Go to previous messageGo to next message
Originally posted by: codeslave.ca.ibm.com
try `eclipse -vm /usr/java6_64/jre/bin/java -vmargs ...`
> eclipse.org.
> eclipse
> eclipse -clean
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Re: JVM terminated. Exit code 13 [message #331970 is a reply to message #331961] Tue, 30 September 2008 15:05 Go to previous messageGo to next message
I try your suggestion:
~/eclipse3.3/eclipse -vm /usr/java6_64/jre/bin/java -vmargs
but still have the same problem.
Re: JVM terminated. Exit code 13 [message #331979 is a reply to message #331970] Tue, 30 September 2008 16:41 Go to previous messageGo to next message
Ok, try this:
http://wiki.eclipse.org/IRC_FAQ#How_do_I_debug_Eclipse.3F_Ho w_can_I_see_what_plugins_are_being_started.3F_How_do_I_start _the_OSGi_console.3F
Nick
Re: JVM terminated. Exit code 13 [message #331981 is a reply to message #331957] Tue, 30 September 2008 17:58 Go to previous messageGo to next message
You built -arch ppc, you probably want something like "ppc64"
By using "ppc" you are likely getting 32 bit version of all the native
libraries, in particular the eclipse executable itself and its
corresponding shared library, as well as the swt libraries.
At a minimum, you will need to create ppc64 versions :
org.eclipse.equinox.launcher.motif.aix.ppc64
org.eclipse.swt.motif.aix.ppc64
And recompile the native libraries for eclipse, I don't know how much of
that recompile will be automated by the source build download.
-Andrew
> eclipse.org.
> eclipse
> eclipse -clean
Re: JVM terminated. Exit code 13 [message #331983 is a reply to message #331981] Tue, 30 September 2008 22:29 Go to previous message
$ sh build -os aix -ws motif -arch ppc64
The os-ws-arch combination of aix-motif-ppc64 is not valid.
Previous Topic:IWorkbenchSiteProgressService and dialog
Next Topic:IMarker - problem view and editor
Current Time: Thu Oct 23 04:26:22 EDT 2025
Powered by FUDForum. Page generated in 0.04248 seconds
